Previous in Forum: Why isn't Fiber Optic an Option for Monitor Displays or Graphics Cards?   Next in Forum: Extremely Thin Drill Bits - True or Not?
18 comments
Carbon Aero Gel
06/11/2015 7:29 AM
I read recently about a graphene-based aero gel that is 7 times lighter than air:only .16 mg/cc. Vs dry air=1.204 and Helium=.1785.
This stuff should actually float,and provide lift.
Due to it's strength,it could fill a blimp and never leak,without danger of losing shape,allowing a lighter structure for framing,etc.
Sounds very safe to me.
Will this bring back lighter than air craft,and erase the memory of the Hindenburg?
http://www.extremetech.com/extreme/153063-graphene-aerogel-is-seven-times-lighter-than-air-can-balance-on-a-blade-of-grass
Re: Carbon Aero gel
06/11/2015 7:33 AM
Is it cheaper than helium by a factor of 1600/1785 ?
Re: Carbon Aero gel
06/11/2015 8:02 AM
It would only float in air if you could keep all the air out of the pores. Aero-gel + air = 0.16 + 1.204 = 1.364 mg/cc (roughly).
Re: Carbon Aero gel
06/11/2015 9:05 AM
I could be wrong,but my understanding was that it was the weight in air,not in a vacuum,so the internal air weight can be disregarded.
But, I could be wrong.
Good Answers: 92
Re: Carbon Aero gel
06/11/2015 9:51 AM
If that's its weight in air, measured on a non-sealed balance pan, then that weight is the mass of the aerogel. The weight of the air around and internal to the aerogel matrix is unrestrained, therefore it exerts a constant pressure on the balance pan that is counteracted by the air pressure underneath the pan.
So the density of the aerogel when calculated dimensionally may be significantly less than the equivalent air density at STP, but that's misleading as the gel is an open matrix. The real density is actually ADDITIONAL to the air mass (or water, vacuum etc.) that fills that matrix.
So it may float away in a breeze, but it will probably sink to the bottom of a container of water if submerged for a long period of time. On the other hand, if the stuff has good compressive strength it would make possible gas free rigid lighter than air craft- exactly the sort of design you see from 300 year old drawings with vacuum spheres!
Re: Carbon Aero gel
06/11/2015 10:04 AM
"I see!" said the blind carpenter as he picked up his hammer and saw.
Good Answers: 92
Re: Carbon Aero gel
06/11/2015 10:30 AM
Actually, would be interesting to see what densities of liquid an aerogel would sink in (eventually of course, it would have to wet into the matrix first).
Re: Carbon Aero gel
06/11/2015 1:44 PM
Re: Carbon Aero gel
06/11/2015 10:22 AM
Imagine enclosing this material in a hot-air balloon envelope, and pulling a vacuum on it,then filling it with hot air. It has great recovery from compression.
With the inherent insulating properties,it would hold heat for a long time.
A certain amount(TBD) of the balloon volume could be reserved, free of the aerogel for altitude adjustment.
This would save a lot of fuel.
Would this work?
Re: Carbon Aero gel
06/11/2015 11:04 AM
Giving up rapid control of the heat, is giving up control of altitude....which is pretty much the only control you have, short of jumping out....
Good Answers: 92
Re: Carbon Aero gel
06/11/2015 11:29 AM
Problem is that air will cool as it expands into the vacuum. Seems to me you'd be much better off with just blowing hot air into it topside and venting the bottom until the desired temperature was reached. Maybe suction would help to get the air flowing through it. I really don't know what the insulation effect would be, other than to reduce convection inside the balloon.
Do you know what the compression of aerogel at 14 psi is??
Good Answers: 137
Re: Carbon Aero gel
06/11/2015 5:33 PM
When I first read this I assumed the pores in the material are evacuated and sealed. In that case the density (total) could in principle be as quoted. I don't know whether that is practical.
If a balloon could be made to take full vacuum but same mass as one filled with hydrogen or helium (which of course it can't) it would have have greater lift than gas-filled.
Re: Carbon Aero gel
06/11/2015 11:33 AM
Well, you are wrong.
Good moaning!
Good Answers: 120
Re: Carbon Aero gel
06/11/2015 3:06 PM
Yes, wrong. The true density of the carbon skeleton will be that of carbon. It is arranged in thin rods to enclose a large space and if you compute density as weight for that large space = very low, but as another said, you must count the air in that space - unless it is sealed with a membrane and the rod structure is strong enough to withstand normal air pressure, in which case you would have a lighter than air balloon.
I doubt it will have the strength, but you might be able to create small spheres that are strong enough to serve in that role?
Per Ardua Ad Astra
Re: Carbon Aero gel
06/11/2015 7:44 PM
Think of a sponge. If it's dry, it floats in water. If it's soaking wet it sinks. Same thing with aerogel, the air weights it down.
It would likely rise if it were infused with helium, at least until the helium leaked out (probably rapidly). It would be lightest still if it were filled with vacuum, but the air pressure would quickly crush it if air did not leak in.
Re: Carbon Aero gel
06/11/2015 8:09 PM
I understand.It is all about displacement.
The molecular weight of the carbon is heavier than air.
Like a ship that displaces it's weight, if you punch it full of holes it will sink,because the steel is heavier than water.
If you keep the water out, it will float.
Likewise with the air in this case.
If they could make an aerogel from a material lighter than air, it would float in air.
Good Answers: 120
Re: Carbon Aero gel
06/11/2015 8:12 PM
Yes, a solid material, less dense than air, would indeed rise until the external density was a match for it.....sadly, it can not be.
Per Ardua Ad Astra
Re: Carbon Aero gel
06/11/2015 9:49 PM
"If it's soaking wet it sinks"
Only if the sponge material has a specific gravity of more than one.
Re: Carbon Aero gel
06/11/2015 9:08 AM
This is why the article talks about this material being balanced on flowers instead of being tethered to a vase of water.
Register to Reply 18 comments
aurizon (2); Codemaster (1); Crabtree (1); HiTekRedNek (4); JNB (3); JohnDG (1); lyn (1); Randall (1); redfred (1); Rixter (1); SolarEagle (1); Tornado (1)
