Previous in Forum: Small Hole Drilling   Next in Forum: Nitrogen Leak Test Procedure
York YK Chiller Condenser Tube Leak
06/14/2015 3:34 AM
dear engineers,
For subject issue . we are using York Centrifugal chiller (model : YK VH TD J4 50JES) .This unit has a sub cooler in the condenser and we are having alot of leaks . The tubes sit on a baffle plate at each end & are supported at four different points inside by a type of mesh wire, now this is where the problem starts. the tubes are leaking at the points where the tubing sits on this mesh it is like the mesh is wearing it's way through the piping from vibration or whatever. We have done vibration analysis etc & all is normal.
Just wondering if anybody else has come across this problem & if so how did you resolve it.
Good Answers: 120
Re: York YK chiller condenser tube leak
06/14/2015 8:21 AM
It might be corrosion caused by the 2 metals touching. Often in situations like this they insert a protective anode/cathode which corrodes instead of the tubes. The type is selected by a corrosion specialist after a review of the metals, fluids and therma; environment involved
Anode
Cathode
Per Ardua Ad Astra
06/14/2015 12:24 PM
06/14/2015 12:38 PM
This is regular stuff....these tubes are periodically replaced....
Re: York YK Chiller Condenser Tube Leak
06/14/2015 3:39 PM
Chicken wire is hexagonal, so it is little wonder that someone would try it in place of drilled/punched/cut baffles.
06/15/2015 12:08 AM
How old the unit is? If it is too old and are not using treated water for the cooling system this type of problem occurs. If it is new and under warranty you can contact the supplier. Do you carry out descaling of the unit regularly as per the supplier's recommendation ?
06/17/2015 12:06 PM
If the tubes are one type of stainless steel, and the mesh is another type of stainless steel, and the environment is anoxic (free of oxygen), on the refrigerant side (as it should be), then apparent to me is the possibility that one or both metals could be becoming de-passivated (loss of oxygen from the surface), and these will exhibit two completely different galvanic potentials (although refrigerant does not strike me as a useful charge carrier for galvanic corrosion cells).
If one metal is considerably harder than the other, then the softer (tube?) metal will experience excessive wear, either due to the thermal cycling of the machine, or to flow-induced vibration "that is normal".
I suggest you seriously should be taking this up with York, as their technical people should be able to find an answer to why this takes place, whether it is common or not, and offer up some sound advice to ameliorate the situation.
aurizon (1); James Stewart (1); lyn (1); mrswamy (1); SolarEagle (1); Tornado (1)
