Previous in Forum: Surface Preparation of SS 202   Next in Forum: Steam Flow Rate
8 comments
How to Calculate the Tank Height
06/20/2015 11:59 PM
o.d is 1100mm dia tank capacity is 2000 liter how to calculate the height of the tank?
Re: how to calculate the tank height
06/21/2015 3:55 AM
Do your own homework.
Good Answers: 141
06/21/2015 5:14 AM
Divide the volume by the surface re: diameter, deduct the surface of the ring of the tank material first and add the height of the stand, pipes and if needed roof.
Plenty of room here
06/21/2015 6:57 AM
Look up volume formula for Cylinder. When you find it solve for the unknown variable and calculate it.
06/21/2015 9:09 AM
Don't forget to include in your calculations the wall thickness, any internal and external structural support members of the tank. Likely the bottom of your tank will not be resting on a flat supporting member so you may have to take into account base plate deformation due to mechanical loading from the mass of the fluid in the tank. If that fluid is some cryogenic or other highly reactive fluid then things can get really complicated.
Good Answers: 120
06/21/2015 1:37 PM
if the id is one mm, the top end will be invacuum, and it might collapse under it's own weight, unless made of unobtainium - grade 3
Per Ardua Ad Astra
Re: How to Calculate the Tank Height
06/22/2015 12:47 PM
By using the formula for the volume of a cylinder, which can be found in most Engineering textbooks, if absent from the inside of the cranium.
06/23/2015 12:20 AM
Taking into account that 1100 (mm) = 11 (dm) and 2000 (liter)= 2000 (dm^3), follow the previous suggestions.
06/25/2015 12:25 AM
This question is not so elementary as it appears at first glance, so let's not get too snarky too soon.
Let's assume the poster is designing a tank and needs to determine the height based on certain criteria. Capacity and OD are common fixed parameters while others are variable.
However, we need more information. We need to know wall thickness, head style top and bottom, and any internal structure or features. Plus on API and ASME tank designs, we need to allow for a freeboard of 10-15%. Also, will the tank be vertical or horizontal? This will effect the selection of top and bottom head types.
Register to Reply 8 comments
aurizon (1); dvmdsc (1); elmi (1); IdeaSmith (1); lyn (1); pdef1949 (1); PWSlack (1); redfred (1)
