Previous in Forum: Temperature Design Standard DIN -43763   Next in Forum: Calibration for Biosignal Device
Interchangeability of RTD's
06/25/2015 2:46 AM
Are the The RTDs interchangeable between 0.1 Ohm at 0°C and 36 Ohm at 260°C?
Good Answers: 69
Re: Interchangeability of RTD's
06/25/2015 8:39 AM
You need to se the temperature chart of each part number, do a google search of the datasheets.
Good Answers: 109
06/25/2015 10:00 AM
What do you think?
RTD
07/09/2015 3:42 PM
I dunno, I don't have my Karnak hat on today.
I suspect that unless you have and compare the charts for the two, you will not know. One thing to try (depending on the applicable temperature range you wish to measure): Use both in the readout device (at separate times), but read them both in ice bath and boiling water bath (or other known temperature standards). If each displays the same R value as the other at the two known temperatures, there is a chance to substitute one for the other.
Register to Reply 3 comments
IdeaSmith (1); James Stewart (1); Yahlasit (1)
