Previous in Forum: Solar Flow Battery   Next in Forum: Carbon Monoxide Question
25 comments
Sterling Silver Centrifugal Casting Problems — Firescale/Brittleness
07/14/2015 5:15 PM
I've been casting for quite a few years and lately i've been having some problems related to the resluting quality of the metal casts.
i mostly cast sterling silver, which is the metal that has been troubling me. 18k gold hasnt been a problem at all.
basically when casting 925 silver i've been encountering big batches of severelly oxidized areas near the sprues, mostly in pieces weighing above 10grs. these oxidized areas are very difficult to resolve since i find that the oxidization generally goes way into the metal mass.
Also these casts tend to be very brittle, a fact that shows mainly when y try to stretch or reshape them (like in trying to adjust a ring size).
i use a mixture of propane and oxygen for my meltings. i try to casts as soon as i can after the metal has all been molten, trying to achieve this with as reducing a flame as i can. i usually cast between 100 and 150 grs each round.
despite my caution i dont seem to be able to solve this issue.
any suggestions/advice?
Re: sterling silver centrifugal casting problems. firescale/brittleness
07/14/2015 5:23 PM
As a non-expert, if your casting processes/methods/timing have not changed, I'd look at the raw material purity.
07/14/2015 5:32 PM
that was of course my first shot. i used different suppliers of metal but i dont seem to avoid the previously described problems. the extent to which i find these problems varies from time to time but i dont seem to manage to avoid it completely, which result in great risk, specially when casting original models. my guess is i am oxidizing the metal too much but my currents skills prevent me from finding a bold solution to this. thanks.
07/14/2015 5:34 PM
Here's some good guidelines that should help...
"Copper Oxide Formation
When sterling is melted without protection and oxygen pickup occurs, the copper will oxidize. Copper oxide in the casting can cause two problems. First, copper oxide inclusions will occur throughout the casting. They really only cause a problem when they are near the surface, where they act as hard spots that stick above the polished surface. Second, a layer of copper oxide can form in and around shrinkage porosity. This is seen on a polished surface as gray, cloudy spots. These spots are usually too deep to be polished out. Figure 8 shows a cross section of a sterling ring; shrinkage porosity can be seen throughout. Also evident are two darker areas: one at the up- per right and the other in the lower left of the casting. These dark areas indicate copper oxide surrounding surface porosity. The presence of cuprous oxide can be confirmed with an optical microscope using polarized light. Figures 9 through 11 show the various views of sterling silver with normal illumination and with polarized light. The first photo of each sequence (9A, 10A, lIA) shows various inclusions that appear black. The second photo in each sequence (9B, 10B, IIB) shows the inclusions as bright red in color, confirming that they are cuprous oxide. In some cases, when the molten sterling is left unprotected for an ex- tended amount of time and/or is overheated, the copper oxide formation is so severe that the surface of the molten sterling develops a rather tenacious skin. This copper oxide skin greatly reduces the fluidity of the metal. The usual result is that many of the fine details on the castings do not fill. In some instances, major portions of the casting do not fill. A telltale sign of this condition is a reddish color on the surface near the incomplete fill. For further assistance regarding any casting problems, it's advisable to contact your metal supplier."
http://technical-articles.hooverandstrong.com/wordpress/improving-your-silver-casting/
07/14/2015 5:51 PM
excellent artice!
07/15/2015 8:15 AM
What would you say is the most effective way of reducing oxygen pickup while attempting centrifugal casting?
as I said I use a propane/oxygen mix.
07/15/2015 2:04 PM
If you look at the top of the linked page you will see ← Previous Next → this will turn the pages of this on-line book which contains the info you seek,,and then some....
To help you out this is a link to the 'next' page...
07/15/2015 11:14 PM
Is there a way to oxygenate the silver prior to pouring? That will eliminate alot of other metals from the batch. Silver can dissolve the most oxygen of any metal, so, if you oxygenate the molten alloy, you can float out the impurities.
Otherwise, you will have to eliminate oxygen from the batch and perhaps pour at a lower temp or use more flux in your batch and scrape it off more carefully before you pour.
Good Answers: 120
Re: Sterling Silver Centrifugal Casting Problems. Firescale/Brittleness
07/15/2015 5:05 AM
Solar Eagle refers to "oxygen pickup". Oxygen from the air dissolves into molten Silver.
As the Silver hardens, this silver is forced out of solution and often damages the casting - rough surface, trapped voids etc. It additionally can oxidise the copper component - as the SE article states.
Oxygen in Silver is a well known problem and this might help oxygen problem casting silver
and this similar search might provide more leads.
casting silver oxygen
Per Ardua Ad Astra
07/15/2015 8:11 AM
Thank you for the feedback.unfortunately the links you posted only redirect me to a google search page, which is the way I found thid forum.
Solar Eagle's reference is great as to determining the causes and possible outcomes of oxidized molten sterling silver but it doesnt quite go deep as to how to prevent it in an open cruicible melting operation previous to a centrifugal casting.
i've read articles that refer on how to prevent oxidization by furnace melting and other variables appliable to vacuum casting experiences, but havent found consistent tips as to preventing this oxygen pickup while attempting centrifugal.
any tips?
Good Answers: 120
07/15/2015 8:16 AM
I assume you failed to read some of the links, your Royal Highness.
Solutions to this problem lie in following links and forums untl you find a solution...
Per Ardua Ad Astra
07/15/2015 8:51 AM
Once again I thank you.
But are there any articles in particular that you would recomend from the aproximately 372,000 ones the search engine throws?
This is an honest question, not a condescendent one.
i found a few amazing papers but havent yet found a pragmatic-on hands tip that succeeds in bringing light to my obvious ignorance.
This is an honest remark, not a condescendent one.
Anyhow I appreciate you investing your time in aiding my quest.
Good Answers: 120
07/15/2015 9:00 AM
The sieving of the details is part of the game.
repeat the search and add several - minus signs after the main terms.
Molten Silver oxygen uptake +forum and so on
the minus terms exclude whatever you decide you want to prune
pruned
Per Ardua Ad Astra
Good Answers: 122
Re: Sterling Silver Centrifugal Casting Problems — Firescale/Brittleness
07/15/2015 9:21 AM
Years ago I worked in a smelter and we used washed Willis Quartz fines for purifying precious metals prior to casting.
This was done by adding a small amount on top of the batch in the oven, allowing a period of time to pass, then skimming the quartz off the top just before pouring began.
The purification time interval was determined by the trial and error method of dipping small samples out of the batch then pouring it into small molds and observing the result until the process was proven.
It worked well on pure gold, silver, & copper as well as mixtures of these with other metals when we made brass and other exotic metal alloys.
Hobbies - CNC - New Member
07/15/2015 9:50 AM
Don't they use crushed lime too?
I seem to remember seeing that on one of the "How it Works" TV programs?
Look here
Here is a CR4 posting from a while ago
Here is a cool PDF on silver casting
Have fun and good luck!
07/22/2015 9:13 AM
thank you for your answer.
how exactly did you carry out the skimming procedure?
07/15/2015 10:54 PM
Would doing the work in a low oxygen environment work? Heating and casting under a flow of something like nitrogen should be practical given the small volume of molten material.
07/22/2015 9:17 AM
I've read stuff about creating a reduced oxygen atmosphere by flowing for example nitrogen.
I just dont know how to manage this nitrogen flow throughout the process.
what wquipment would one use?
Good Answers: 32
07/15/2015 11:14 PM
I found that using Borax as a cover flux for melting chrome copper and copper was very effective in preventing gas pick-up and copper is basically next in line in difficulty to silver. Assume by centrifugal casting that you are using silicone rubber molds in a centrifugal casting machine as made by Tekcast or comparable. Since these are generally made for white metal applications with a 900 F range, the melting temp of sterling being considerably higher, up around 1800 F for 925, it may be in your choice of mold materials which I don't see a reference to. Good venting in your mold is also necessary to remove the air in the mold as the metal is poured in.
Since this is something to consider "The word "sterling" represents the best known and most respected quality marking in use today. It signifies that the article so stamped is made from silver with a silver content of at least 92.5% by weight, with no stipulation about the remaining 7.5%. The reason for the relatively "low" silver content in sterling is a practical one: finer grades of silver are too soft for everyday use. Alloying elements are needed to increase strength and hardness. Since copper provides the best combination of wear qualities, it is the most common alloying element used by jewelers and silversmiths." Normally copper is the other 7.5% but with the high price of copper these days your supplier may have switched to a cheaper material like zinc and zinc rich alloys can cause an alloy to be hot short and be a cause of your shrinkage problem. Check the analysis or the supplier to see if a change was made.
Spinco
07/22/2015 9:25 AM
Thank you for the feedback Spinco. Actually I pour into a refractory plaster mould (otherwise known as investmente mould). I am quite certain that the copper I use is electrolytic copper and should be 99% pure. I am wondering if the quality of the investment can have an influence in the result of the casting in terms of oxydation. I tried two new different investments in the past months. Both of them were significantly cheaper . i didnt see a substantial difference as to the quality of the castings in terms of superficial defects or cracking of the moulds. but I am not very knowledgeable as for chemical processes occuring in the investments when heated or when carrying out the casting sequence.
Good Answers: 32
07/22/2015 10:01 AM
You use the term "refractory plaster". Is this a water based plaster or an ethyl silicate based investment? I would not recommend the use of a water based plaster at the high temperatures needed for copper or silver. Plasters will lose their bond above 1800 degrees F and revert to dry plaster with the water released into the metal causing porosity issues. What are your new investments and methods of coating? Spent 40 years in Foundry industry and am familiar with several investment methods as well as Sand and Permanent Molds.
Spinco
07/16/2015 3:12 AM
Interesting blog (usual on CR4 I find).
My ex in the UK is a registered silversmith in the UK, and I was her "HOT" man for years....but I never saw this problem before. But we did not use a centrifugal unit either...
My thoughts, over and above all the excellent posts already made, is has anything changed in your methods? If it worked before, it should work now I feel.....
Is the moulding plaster (as a name to use!) the same type and quality as you used before?
Is it the same wax and wax supplier?
Have you changed the silver temperature? Do you even measure it, or is it done by "experience"?
Is the gas burner, burning all the oxygen? Do you heat the silver surface, or just the crucible?
Is the (lost) wax being fully removed?
Is it a different wax supplier?
Are you heating the mould sufficiently before casting? Do you even heat it before use?
Have got the same problem when casting but without the centrifugal unit?
Are the sprue's maybe too small and slowing the metal down too much? Try increasing the width of the sprue's.
I am sure that I have not covered everything that may have been changed, but spend a moment or two reflecting upon what could be going wrong for you, just in your methods......maybe only some small thing has been changed....the flux or the flux supplier.....
Best of luck, keep us informed.
Good Answers: 32
07/16/2015 9:06 AM
You've probably seen this but just in case you haven't and if this your method it may be of some benfit: https://books.google.com/books?id=e_09Enaf4tIC&pg=PA103&lpg=PA103&dq=melting+with+a+reducing+flame&source=bl&ots=YrbVkzdR2L&sig=E80E13q4MesKl1KKNczE4WT0LbA&hl=en&sa=X&ved=0CC4Q6AEwBGoVChMIyoXR6drfxgIVy82ACh0PbACx#v=onepage&q=melting%20with%20a%20reducing%20flame&f=false
Spinco
Good Answers: 120
07/16/2015 9:09 AM
Per Ardua Ad Astra
07/17/2015 1:32 PM
What temp are you casting at. It sounds like you are pouring too hot.
07/22/2015 9:31 AM
Hi silvCrow. To be honest I dont measure the temperature of the molten metal.
My equipment is quite rudimentary if something. It works well but of course when it comes to determining details or facts like these it makes it harder to be able to adjust the methodology.
I try to melt slowly and with a minimum of oxygen flow through the torch. but it has happened to me a few times that the metal got solid too fast and the cast came out incomplete, so there is always the fear of this happening again when letting the centrifugal arm free.
Register to Reply 25 comments
Andy Germany (1); aurizon (4); cristle (1); Deefburger (1); fede (9); lyn (1); Original_Macgyver (1); SHOCKHISCAN (1); silvCrow (1); SolarEagle (2); Spinco (3)
