Previous in Forum: Surge Diverter   Next in Forum: Differences Between Switchgears and Switchboards
Difference Between IR Receiver and IR Led
07/21/2015 4:12 AM
How can i tell the difference between an IR receiver and an IR led. I have two Diodes one, is a black one and one is white. I have a friend who says that the black one is always an IR receiver and the white one is always an LED. I wanted to get a confirmation or more information on this as I can't find any info on the net. Thank you Varun Rao
Pathfinder Tags: IR Receiver LED
Re: Difference between IR Receiver and IR led
07/21/2015 5:32 AM
Normally the transmitter will be clear; the receiver will be dark, blackish or red.
Do a search on Digikey for infrared transmitter and receiver diodes: you can hover over the image at the left to get a larger picture.
07/21/2015 5:57 AM
Interestingly, a LED will also act as a receiver...
http://makezine.com/projects/make-36-boards/how-to-use-leds-to-detect-light/
07/21/2015 7:39 AM
The IR receiver usually has a dark, typically flat, lens on the front to block out sunlight and pass only the specific IR wavelength it is designed to respond to.
The IR emitter typically has a clear dome lens on it to help focus the IR light into a beam. It doesn't usually need a dark lens since it is emitting, not receiving energy. Depending on the wavelength of the IR diode (like < 900 nm), it might emit a small amount of red energy you can see in a dark room.
Good Answers: 225
Re: Difference Between IR Receiver and IR led
07/21/2015 7:51 AM
Just a bit of useless information which you may or may not be aware of...If you want to see if an IR transmitter is actually transmitting...Look at it through the screen of a digital camera.
07/21/2015 10:08 AM
Some camera filter out the IR, come don't. Test your camera with a TV remote.
07/22/2015 11:00 AM
Also, some cameras have an 'evening light' mode, where they remove the IR filter, and activate a small IR LED to help brighten the shadowed objects.
Cameras may vary, so when in doubt, Read The Funny Manual. ;)
Register to Reply 6 comments
adreasler (1); Randall (1); Rixter (2); spades (1); Usbport (1)
