Previous in Forum: Safety Critical Postponement Procedure   Next in Forum: Joint Efficiency Relation with Radiography (NDT)
Important Basics of Welding for Newbies
07/24/2015 6:07 AM
Welding has been around for centuries. One of the first used welding processes was forge welding. The forge welding involves joining two metals through the process of heating, pounding and striking. Over time, welding has witnessed some advancements. The new methods and techniques have allowed welding to leave the confines of industrial settings, and now can be practically done wherever underwater or outer space!
Along with the welding history, the ability of strongly joining two or more pieces of metal has been noticed as the fundamental for our advancements in all the areas of life. Grasping the welding basics can be very beneficial not only at work but also around the house, farm, or workshop. That is why welding is the skill almost anyone can enjoy an advantage from, whether young or old, male or female.
Why Welding?
With any metal equipment or machinery at hand, welding will be sure a useful skill you obtain. Below include some common goals of a welding job:
. Fix stress cracks . Reinforce weak joints. Cut/ Shape new parts and adapters from the raw plating.
For such chores, many welders trust in the arc welding process. This is a method that during the welding process, an electric current jumps through an air gap between a positive electrode and a negatively charged steel plate, and creates a huge amount of heat. This heat is produced at the end of the welding rod. That is when metal can be melt. It is, indeed, more complicated than that though, the concept is just the same.
Perhaps AC arc welding is the most typical and economical welding method applied today. A simple AC welder can be located just about anywhere like your local farm store or home improvement center. This welding process is perfect for most of your normal welding jobs. Thus AC arc welding is just ideal for the beginners.
Mitigate Your Risk
Though arc welding isn't exceptionally complicated, there are some risks and hazards you should be aware of:
1. Exposing radiation 2. Flying sparks (in the form of molten metal globs) 3. Electric shock 4. Fumes 5. Damage to your eye6. Burns
Still, those inherent risks of welding can be significantly reduced by wearing protective clothing, welding helmets, and other gears. Following are some tips to help with your safety while arc welding:
. Sure you work on a dry floor. Put on thick rubber shoes and dry leather welding gloves.. Make sure to employ insulated electrode holders.. Check to ensure that your equipment is all grounded properly.. Keep your work area ventilated properly for avoiding any inhalation of possibly toxic fumes.. Be on the watch for flying bits of melt metals. . Most significantly, be aware of anyone around you. If they aren't wearing the right gear, keep them away from your project.
This is helpful information for your start-up in welding career. Give it your note!
Good Answers: 137
Re: Important Basics of Welding for Newbies
07/27/2015 7:43 AM
OK what's the question?
