Previous in Forum: Important Basics of Welding for Newbies   Next in Forum: What is the Physics Behind More Efficient Air Conditioners?
8 comments
Joint Efficiency Relation with Radiography (NDT)
07/24/2015 9:40 AM
in my fabrication drawing i am specifying radiography as NIL. what should be my joint efficiency.
and if radiography as 10% or 100%, what should by my joint efficiency.
Pathfinder Tags: joint efficiency radiography
Good Answers: 26
Re: Joint Efficiency Relation with Radiography (NDT)
07/24/2015 11:17 AM
Which code?
07/24/2015 11:21 AM
ASME SEC VIII DIV 1
07/24/2015 12:26 PM
All joints should be 100% efficient.
Otherwise they may leak.
07/24/2015 3:06 PM
This might not be up to date, but if you do full radiography, you can claim 100% weld efficiency. For spot radiography (which may be the same as the 10% you mention), you can claim 85% weld efficiency. With no radiography, 70%.
Good Answers: 104
07/24/2015 8:03 PM
what is NIL?
Good Answers: 137
07/27/2015 4:23 AM
Zero, zilch, nada, none (etc)
07/28/2015 4:29 AM
Basically Joint Eff. Specifying depends on the following:
- specify the weld joint gategory from Para. UW-3
- The weld description from Para. UW-12 with Table UW-12.
GENERAL: for full radio gragh. 100%, for spot 85%. in case of lethal material service use full RG. AS PER (UW-2 SERVICE RESTRICTIONS).
enlightenment is blessing and self-denial is a good recipe
07/28/2015 9:09 AM
friends...thanks for your valuable comments...
Register to Reply 8 comments
bigg (1); blackpanic73 (1); Codemaster (1); JIJU BALAN (2); lyn (1); texasron (1); Tornado (1)
