Previous in Forum: % Impedance of Three Winding Transformer   Next in Forum: Underground Power Line Depth
8 comments
Transformer Placed Directly on Foundation
07/31/2015 12:37 AM
I recently saw a transformer placed directly on foundation rather than on rollers, and it was a 125MVA power transformer. Can there be any specific reason to do that, as it was fixed and wielded to foundation through base plate?
Pathfinder Tags: transformer
Good Answers: 70
Re: Transformer placed directly on foundation
07/31/2015 1:56 AM
There is, if installed in California or Oklahoma, they don't want them rolling around during an EQ Oh yeah, maybe a better chassis ground too?
07/31/2015 1:56 AM
Different local seismic conditions, maybe. I have never seen a transformer on rollers, and I wonder what wiring arrangements could accommodate a significant amount of rolling. Maybe RAM can tell us.
Re: Transformer Placed Directly on Foundation
07/31/2015 4:56 AM
The transformers are mounted directly on foundation to avoid their movement in earthquake situation. It is necessary to have their wheels locked or mount directly on foundation
07/31/2015 5:39 AM
The only time I saw large transformers on rollers was to allow them to be removed from installed position (between isolation walls) into open space for major overhauls. I think there were four in that bank, but my memory of the site visit nearly 35 years ago is a bit hazy.
If the transformer you saw was easily accessible, then it would not need to be moved for service.
Good Answers: 122
07/31/2015 9:29 AM
Other than medium and small portable power skids I have not seen any large transformers that were/are not sitting on a foundation and secured with bolts to the foundation base plate(s).
All transformers vibrate and grow or shrink from changes in temperature so they must be secured to prevent movement.
Seismic activity is one of the reasons for doing so and another reason to do so is so that the transformer bushings stay in alignment with their connections to avoid damage from horizontal stress.
It is also very important that large transformers are evenly supported and level so that they do not suffer structural damage, develop coolant leaks, and/or suffer internal winding or lamination damage.
Good Answers: 445
07/31/2015 2:36 PM
Rigid mounting is the norm, on rollers only in special situations such as high reliability/availability installations where the cost of downtime exceeds the extra cost of the sparing scheme.
Putting 150 +/- tons on wheels is never a good idea, and if done, the transformer is rolled into place and then a base plate/frame is jacked up to meet the bottom frame and take most of the weight off of the wheels. Motion of any sort is bad for the bus work and cabling attached to the bushings.
07/31/2015 11:23 PM
Location of transformer should be adjustable for aligning the bushings to those on wall feeding power.
pnaban
Good Answers: 445
07/31/2015 11:35 PM
In other words the engineer(?) specifying the external dimensions of the transformer bushings doesn't know where the connections are, and a 150,000kg transformer has to be jockeyed around to fit??? Nonsense, that's the tail wagging the dog.
Register to Reply 8 comments
dj95401 (1); hrk (1); Just an Engineer (1); pnaban (1); RAMConsult (2); SHOCKHISCAN (1); Tornado (1)
