Previous in Forum: Out Side Cables   Next in Forum: Transformer Placed Directly on Foundation
% Impedance of Three Winding Transformer
07/31/2015 12:29 AM
We have a 50 KVA Dyn11yn11 (dual winding) transformer.
Input= 50 KVA, 132 KV, Vector Group= Dyn11yn11
Output 1= 25 KVA, 6.3 KV
Output 2= 25 KVA, 6.3 KV.
Can you please tell me the per unit or percentage impedance of the three winding of the transformer?
i.e.
primary to secondary 1 ?
primary to secondary 2 ?
secondary 1 to secondary 2 ?
Pathfinder Tags: impedance of transfomrer
Re: % Impedance of Three Winding Transfomrer
07/31/2015 4:02 AM
Good Answers: 445
07/31/2015 7:57 AM
Looks like this one keeps getting passed from interviewee to interviewee, except this time even less information is provided, so the answer is: No we can't.
Re: % Impedance of Three Winding Transformer
07/31/2015 11:19 PM
There are 3 cases to be considered-1)both secondary unloaded,2)one loaded,3)both loaded-for interacting of load currents on primary.
pnaban
Good Answers: 19
07/31/2015 11:36 PM
The rating of transformers should have been in MVA. 50 kVA for 132 kV 3 winding transformer seems to be very low. You get the details from the Transformer manufacturer. Percentage impedance of the transformers depend on the design of the transformer and other winding parameters.
Ramesh,Freelance Electrical/automation Consultant
09/25/2015 1:21 AM
The only information for your transformer percentage impendence, is to refer back to your transformer test report. It is not easy to calculate the percentage impedance of your transformer with these data's. What is your transformer fault level. Do you have it? May be if you have the transformer faults level then maybe we can do reverse calculation to find out your transformer impendence.
lyn (1); pnaban (1); RAMConsult (1); ramvinod (1); Simon Wan (1)
