Previous in Forum: 24 Hours Hydrostatic Test   Next in Forum: Natural Resonance
16 comments
Another Whatizit
08/07/2015 8:09 AM
Another piece I need help identifying.
It is a pulley and sheave from an old Foley Belsaw Planer.
The company said that they did not supply the pulley or sheave,and had no idea
where to get a replacement.
The pulley is fine, but the adapter sheave is shot.
I have looked for a similar sheave or collar but have been unsuccessful.
It is not a taper lock,nor a cam-loc,it is one I have never seen before.
The photos above show the front and back side of pulley and the threaded hub.
I hope to be able to use the same pulley,but as a last resort,I will replace the whole
shebang.
I am considering,as a last resort to weld a locking collar to each side of the hub and
using setscrews to anchor to the motor shaft.
Re: Another Whatizit
08/07/2015 8:27 AM
Can you get one of these in the correct size to work for you?
http://pdf.directindustry.com/pdf/fenner-drives/keyless-locking-devices/11744-180374.html
You may need to enlarge the bore in the pulley to get one to fit.
Good Answers: 26
08/07/2015 8:27 AM
Wedge lock?
Good Answers: 266
08/07/2015 8:49 AM
MAybe find something here that will work for you.
http://www.sdp-si.com/estore/coverpg/Shafts.htm
08/07/2015 11:36 AM
did you try Mcmaster
They have items that look similar, you may even be able to substitute it.
08/07/2015 1:44 PM
Good Answers: 141
08/07/2015 9:11 PM
You could find one in the bush, in the Bahamas on a washmasjien.
Plenty of room here
08/08/2015 7:27 AM
Thanks to everyone for their valuable advice and time.
After much deliberating,I have decided my best course of action is a 2piece clamping
collar on each side of the pulley.
That way,I can keep it original as far as possible,and will allow me to compensate for
wear on the motor shaft without a complete rebuild of the shaft,which would involve
disassembly of the motor,build up shaft with weld,then turn down on a lathe to
original dimensions.
If not for the motor shaft wear,a new pulley would be best.
Like all things in nature,I am taking the path of least resistance.
Thanks Again!
Good Answers: 42
08/08/2015 10:58 AM
That looks like an easy job for a machine shop. They can make a new nut / adapter for you.
If the motor shaft is worn, take the motor to a motor repair shop. They can sleeve the shaft and return it to the correct diameter.
08/08/2015 5:00 PM
Easy yes,but cheap?NO!
If I had a lathe, and broaching tools,I could do it myself.
I could fix the motor shaft,and bore and make the bushing for the pulley.
You can't sleeve the motor shaft,it has a 1/4" keyway.
It must be built up with weld and turned back down to original size.
Yes,the pulley could be bushed to original size,and a key cut into the bushing.There is enough metal in the pulley to do this without compromising the strength too much.
I have seen it done many times,and done a few myself.
I am after an effective low cost solution,which I believe I have found with the split-clamping collars.
Thanks for the feedback anyway.
Good Answers: 42
08/08/2015 5:49 PM
I am spoiled - I have the lathe, milling machine, and welders in my shop.
Cheap and keeping original is usually not said in the same sentence!
If the shaft is worn it probably is no longer true, so things are going to wobble and probably fail prematurely again.
08/08/2015 10:00 PM
The shaft is only .025" out of round,and can be trued up with a file and dial indicator.
The clamps will allow me enough space to get everything concentric again.
I will use a dial indicator and get everything right.
Then I will tack-weld the collar to the pulley,just one half of the collar.
I will do this for both sides of the pulley.
The other half of the collar has to be free to tighten on the shaft.
Once it is tightened, the collars will be anchored with a taper bore pin on both
unwelded halves.
This will allow disassembly at a later time if needed.
This is not the way I would do it if I had the $$ or tools to do it properly,but it will
have to do for now.
This leaves me the option to do it later when finances allow if I find it nescessary.
I don't intend on using the planer on a daily basis,so it may last a long time.
Wish I had your equipment!
Good Answers: 42
08/18/2015 11:02 PM
There is quite a community of hobby machinists you may be able to tap into.
Also, your local high school / technical school may do it "for free" just for the challenge.
Canada - Member -  Member
Location: Hamburg NY (just south of buffalo) pre-Hamburg(1998) home was the Yukon territory of Canada
Good Answers: 27
08/11/2015 7:02 AM
try these folks,
http://www.intrinsicdevices.com/unilok_applications.html#Shaft_Clamps
Nothing is fool-proof to a talented fool
08/12/2015 9:57 PM
Would you be interested in having a machinist remaking a copy of the original?
08/19/2015 8:40 AM
If that is kind offer to do it, it is sincelry appreciated,however,I had already ordered the split-collar clamps when I received your email.
I welded one half of the split collar to the bushing,after precisely centering it,one on each side of the bushing.
The other half of each collar was attached to the welded side with allen-head screws.
http://www.ruland.com/ps_collars_shaft_sp.asp
The runout was minimal at .002",and the collars clamp very tightly,and allowed me to rotate them on the motor shaft to find the least amount of runout before tightening them,in effect,using offset runouts of the motor shaft and clamps to cancel each other.
It seems to be an economical and effective method.
A big thank you to everyone that contributed to solving this problem.
Some of the links and advice led me eventually to the chosen solution,which would not have occured to me otherwise.
Good Answers: 27
08/13/2015 9:39 AM
this looks like what you need...http://www.sdp-si.com/shaftloc/
Register to Reply 16 comments
dvmdsc (1); GW (3); HiTekRedNek (4); lonster (2); Massey (1); Munster (1); ozzb (1); phoenix911 (1); SolarEagle (1); texasron (1)
