Previous in Forum: Natural Resonance   Next in Forum: Relationship Among Mechanical Properties.
17 comments
Bearing Overheat
08/09/2015 12:35 PM
Dear All,
I'm doing an FMEA for Bearing that uses grease as the main lubrication.
I've identified several failure causes for bearing overheating (above 90 degrees Celsius):
1) Overgreasing
2) Undergreasing
3) Loose Fits
4) Loss of Lubrication (leakage)
5) Wrong Type of grease used
6) Vibration??
The assumption number 6, I want to ask:
1) in your experience, does vibration in bearing normally causes overheating?
2) In bearings, How is the vibration and heat relates to one another in the process of overheating? When the vibration goes above recommended limits, does the temperature also rises above the normal value (less than 90 degrees Celsius)? or when the bearing overheats does that mean it must also be vibrating above normal limits?
3) In what ways does vibration causes overheating? Because it is known that vibration is caused by many things such as misalignment, unbalance, mechanical looseness, etc.
Please share your thoughts regarding this.
NB: Would there be any other cause for bearing overheating other than those stated above? Excluding environmental cause and human error.
Best Regards,
Re: Bearing Overheat
08/09/2015 1:02 PM
I'd look for "effects of vibration on bearings" on the net.
There are 14,000,000 articles written by bearing "people".
Asking the forum for single anecdotal, personal experiences of causes will not yield good results.
Here's one: Sound and Vibration in Rolling Bearings.pdf
YOU are doing the analysis and I have provided you with a source you requested. Good luck.
Now, go to work.
08/09/2015 2:05 PM
08/09/2015 3:05 PM
I'd add mixing grease types together into that...be consistent, don't mix
08/09/2015 5:10 PM
Yes, vibration can cause or contribute to overheating. It imparts kinetic energy to the bearing, which converts to and dissipates as heat.
Good Answers: 444
08/09/2015 10:20 PM
You need to educate yourself on the finer details of bearings by reading the above references and more' then you will add these causes of failure to your list:
7) Wrong bearing type,
8) Wrong bearing material,
9) Misalignment,
10) Improper installation,
11) Seal failure,
12) Contamination,
13) Inadequate lubrication pressure,
14) Inadequate lubrication flowrate,
15) Inadequate clearances/tight fit,
16) Inadequate/improper maintenance,
17) Improper fitment,
18) Improper loading,
19) Improper specification,
20) Unexpected shaft currents.
And those are the ones off the top of my head, there are more. You need to get the assistance of a bearing SME (Subject Matter Expert) to ensure that you have "barked up every tree".
I suggest that you also look into the methodology of doing a FMEA (Failure Modes and Effects Analysis), where you'll learn that you should elaborate as many possible modes as can be found before you start trimming your fault tree; otherwise the one that you missed will be discovered when someone else performs a RCA (Root Cause Analysis) of the failure and finds the one failure mode that you didn't account for.
08/10/2015 12:56 AM
13 FAILURE MODE AND 129 FAILURE MECHANISM
Bearings
Bearings
SKF List of bearing failure causes - Bearing failures and their causes - Product information 401
failure modes
failure mechanism
Category
Wear
Wear caused by abrasive particles
Bearing Wear
Abrasive particles, such as grit or swarf that have entered the bearingLube contamination by inclusionWear caused by inadequate lubrication
Lack of cleanliness before and during mounting operationLube contamination by inclusionWear caused by vibration
Ineffective sealsLube contamination by ingress
Indentations
Lubricant contaminated by worn particles from brass cageLube contamination by ingressIndentations caused by faulty mounting or overloading
Lubrication contamination (wear particles)Lube contamination by ingressIndentations caused by foreign particles
Lubricant additives gradually been used upLube chemical degradation
Smearing
Lubricant has lost its chemical lubricating propertiesLube chemical degradationSmearing of roller ends and guide flanges
Lubricant loss through sealLubricant lossSmearing of rollers and raceways
Lubricant has leaked awayLubricant lossRaceway smearing at intervals corresponding to the roller spacing
Lubrication contamination (external liquid ingress)Lube contamination by ingressSmearing of external surfaces
Lubrication contamination (liquid product ingress)Lube contamination by ingressSmearing in thrust ball bearings
Lubrication contamination (dust and dirt ingress)Lube contamination by ingress
Surface distress
Lubrication contamination (solid product ingress)Lube contamination by ingress
Corrosion
Lubrication contamination (sand and material from within castings, flaking protective coatings, rust from inside castings, etc)Lube contamination by ingressDeep seated rust
Bent shaftsInstallation errorFretting corrosion
Skewed ring from burrs or dirt on bearing mounting surfaces and bearing abutment surfacesInstallation error
Damage caused by the passage of electric current
Shaft shoulders which are not perpendicular to the bearing abutment surfaceInstallation error
Flaking (spalling)
Locking nut faces which are not perpendicular to the bearing seating faceInstallation errorFlaking caused by preloading
Non-concentric bores on which the bearings are mounted leading to an angular axis of rotation of the shaft and thus misaligning the rotating axis of the bearingsInstallation errorFlaking caused by oval compression
Reverse Loading Failure is one such failure which occurs due to the bearing getting loaded in the opposite direction in which it is intended to bear the load. This type of failure is quite common in angular contact and thrust bearingsInstallation errorFlaking caused by axial compression
Bad bearing supplied (especially cheap bearings made of inferior material)Material strength failureFlaking caused by misalignment
Solids were introduced into the system during the assembly process because of a lack of cleanlinessLube contamination by inclusionFlaking caused by indentations
Shaft coupling bore machined off-center / skewedInstallation errorFlaking caused by smearing
Flaking caused by deep seated rust
Bearing Overheated
Clearance looseness (shaft shrinkage)Incorrect fits and toleranceFlaking caused by fretting corrosion
Clearance looseness (housing expansion)Incorrect fits and toleranceFlaking caused by fluting or craters
Clearance looseness (loose fit shaft)Incorrect fits and tolerance
Cracks
Clearance looseness (loose fit housing)Incorrect fits and toleranceCracks caused by rough treatment
Spalling of race waysLube contamination by inclusionCracks caused by excessive drive-up
Inadequate or improper lubricationLube contamination by inclusionCracks caused by smearing
Excessive preload on account of fits being too tightLube chemical degradationCracks caused by fretting corrison
Insufficient heat transmission from housing due to build-up of material and product over casingTemperature change
Cage damage
Rapid cooling of housing causes shrinkage and reduction in clearanceTemperature changeVibration
Incorrect viscosity of the lubricantLube chemical degradationExcessive speed
Incorrect lubricant chemistryLube chemical degradationWear
Form 'varnish' residue and 'coke' at elevated temperature that destroys the ability of the grease or oil to lubricate the bearingLube chemical degradationBlockage
Oil level too lowLubricant lossOther causes of cage damage
Oil level too highLubricant excessive
Plugged oil return holesLubricant excessive
Over greased bearingLubricant excessive
Under greasing bearingLubricant insufficient
Suction pressure too high and causing axial thrustOperational induced stress
Out-of-balance rotating elementUnbalance
Hydrogen embrittlement or blistering by water within microscopic cracks on raceways and rolling elementsLube contamination by ingress
Insufficient clearance in labyrinth sealsIncorrect fits and tolerance
Base frame distortedIncorrect fits and tolerance
Process temperature conducted along shaftTemperature change
Normal aspiration as the pump cooled down, and the moisture laden atmosphere entered the bearing caseLube contamination by ingress
Axially mislocated shaft couplingInstallation error
Grease or lip seals too tightInstallation error
Brinell and False Brinell
Hit during mounting / installationInstallation error
Dented by self-weight load when standing-stillOperational induced stress
Dented by vibration impact loads when standing-still e.g. machinery transported on rough roadsOperational induced stress
Situated close to machinery producing vibrationsOperational induced stress
Mounting pressure applied to the wrong ring during installationInstallation error
Excessively hard drive-up on tapered seating during installationInstallation error
Overloading while not runningOperational induced stress
Excessive preload on account of fits being too tightIncorrect fits and tolerance
Smearing on installation produces microscopic surface cracksInstallation error
Stuffing box packing overtightenedInstallation error
Creeping Slippage
Ring fit is oversizeIncorrect fits and tolerance
Ring fit is wornIncorrect fits and tolerance
Fretting corrosionIncorrect fits and tolerance
Smearing rollers and raceways
Smeared roller ends from sliding under heavy axial loading and with inadequate lubricationIncorrect fits and tolerance
Roller acceleration on entry into the loaded zone due to too much clearanceIncorrect fits and tolerance
Load is too light for the speedIncorrect fits and tolerance
As bearings are being mounted, the ring with the roller and cage assembly is entered askew, without being rotated during insertionInstallation error
Blows applied to the wrong ring or heavy preloading without rotating the bearingInstallation error
External surfaces of heavily loaded bearings from movement of the bearing ring relative to its shaft or housingIncorrect fits and tolerance
Slip fit is too loose on sliding ringIncorrect fits and tolerance
Smearing Thrust Ball Bearings due to rotational speed is too high in relation to the loading. The centrifugal force then impels the balls to the outer part of the shallow raceways. There the balls do not roll satisfactorily and a great deal of sliding occurs at the ball-to-raceway contactsOperational induced stress
Surface Distress Cracks
Inadequate lubricationLubricant insufficient
Improper lubricationLube chemical degradation
Corrosion - Deep seated rust
Presence of water, moisture over a long period of timeLube contamination by ingress
Presence of corrosive substancesLube contamination by ingress
Corrosion - Fretting
Fit too looseIncorrect fits and tolerance
Shaft seating with errors of formIncorrect fits and tolerance
Housing seating with errors of formIncorrect fits and tolerance
Electrical Erosion
Electrical fluting due to passage of electric current through rotating ringElectrical induced damage
Electrical fluting due to passage of electric current through non-rotating ringElectrical induced damage
Earthing problem in equipmentElectrical induced damage
Raceway Spalling
Excessive drive-up on a tapered seatingIncorrect fits and tolerance
Excessive preload adjustment e.g. Single row angular contact ball bearings or taper roller bearingsIncorrect fits and tolerance
Temperature differential between inner and outer rings too greatIncorrect fits and tolerance
Foreign particles in the lubricant, metal particles from within the system, etc allow wear particles to be jammed between roller and race causing impact stressLube contamination by ingress
Cavitation induced stress overloadOperational induced stress
Vibration induced stress from running off BEPOperational induced stress
Clearance tightness (shaft expansion)Incorrect fits and tolerance
Clearance tightness (housing shrinkage)Incorrect fits and tolerance
Clearance tightness (tight shaft fit)Incorrect fits and tolerance
Clearance tightness (tight housing fit)Incorrect fits and tolerance
Pinched bearing (shaft ovality excessive)Incorrect fits and tolerance
Pinched bearing (housing ovality excessive)Incorrect fits and tolerance
Pinched bearing (pipe stress distortion)Incorrect fits and tolerance
Pinched bearing (Soft foot causing frame distortion)Incorrect fits and tolerance
Distorted bore of Plummer blocks from mounting on an uneven base becoming oval when the base bolts are tightenedInstallation error
Incorrect mounting, which results in axial loading, e.g. excessive preloading of angular contact ball bearings and taper roller bearings.Installation error
The non-locating bearing has jammed.Incorrect fits and tolerance
Axial freedom of movement has not been sufficient to accommodate the thermal expansion.Installation error
Cracked Rings
Blows, with a hammer or hardened chisel, have been directed against the ring when the bearing was being mountedInstallation error
Fatigue cracks (installation misalignment cyclic overloading)Installation error
Fatigue cracks (differential frame growth misalignment cyclic overloading)Incorrect fits and tolerance
Fatigue cracks (bent shaft cyclic overloading)Installation error
Fatigue cracks (shaft deflection from running off BEP)Operational induced stress
Fatigue cracks (Smearing during installation causes surface crack initiation)Installation error
Fatigue cracks (Fretting corrosion caused crack initiation)Incorrect fits and tolerance
Sliding under heavy axial loading and with inadequate lubricationInstallation error
Cage Damage
Fatigue cracks (vibration forces of inertia are so great as to cause fatigue cracks to form in the cage material, after a time leading to cage fracture)Unbalance
Fatigue cracks (run at speeds in excess of cage design subjecting it to heavy forces of inertia that may lead to fractures)Operational induced stress
Fatigue cracks (bearing rings are fitted out of alignment with each other, the path of the rollers take an oval configuration. If the cage is centred on the rollers, it has to change shape for every revolution it performs)Installation error
Severe acceleration and retardation, in conjunction with fluctuations in speed cause forces of inertia. These give rise to considerable pressure on cage contacting surfaces, with consequent heavy wearOperational induced stress
Abrasive particlesLube contamination by inclusion
Fragments of flaked material or other hard particles may become wedged between the cage and a rolling element, preventing the latter from rotating round its own axisLube contamination by ingress
Bearing is severely misalignedInstallation error
Seized Bearing
Metal to metal contact cause micro-weldingLube chemical degradation
Clearance tightness causes lack of rolling element rotationIncorrect fits and tolerance
Inadequate lubrication (viscosity too low)Lube chemical degradation
Inadequate lubrication (moisture in lubricant)Lube chemical degradation
Excessive mechanical overload (bearing too small in surface area)Design error
Excessive mechanical overload (high operating load)Operational induced stress
Rolling element jammed and not rolling due to solid contaminantLube contamination by ingress
Rolling element jammed and not rolling due mechanical stressIncorrect fits and tolerance
Grease or lip seal contact on the shaft, right next to the bearings. These seals can add as much as 38°C (100°F) to the shaft temperatureDesign error
Lock nut came looseInstallation error
13
129
IF IT IS NOT CLEAR TEL ME I WILL SEND EXCEL SHEET - REGARDS
08/10/2015 3:12 AM
I find it more helpful if you also tell us the type of bearing....Plain, ball, roller and and and.....
Though I personally feel that most bearings don't like vibration much, though I bet that there are bearings around that can handle vibration better than others....though I am far from being an expert.....
If I was you, I would ask a bearing specialist company for help and advice.
Also, posting Anon is VERY unfriendly.........and unlikely to help you much either.....
08/10/2015 5:19 AM
Dear Anon, Yours is an astute question, in my opinion, as we often speak of bearing failure due to (misalignment, unbalance, etc.) vibration in the rotating component supported by the bearing component(s). The failure mode 'vibration' does cause overheated bearings; however, the relationship between 'vibration' and bearing temp is nonlinear. Moreover, said relationship will differ depending on vibration frequency(s). With that said, a high bearing temp does not imply 'excessive' vibration above 'normal limits' unless one defines 'limits' by vibration frequency. For example, I've seen 2xRPM frequency vibration (typical of misaligned shaft components) cause heating at a slower rate over time than, say, multiple frequency, vibration. Vibration causes heat due to increased friction energy as 'tangent load forces' induce diminished 'tangent lube-gap' between rotating bearing surfaces. Should metal-to-metal contact then occur within the rotating bearing assembly, frictional forces lead to component deformation, increased friction, and more heat.
08/10/2015 9:20 AM
I thank you all for the replies,
Simply, my real main question was, how can vibration become the cause of overheating?
In an FMEA, by stating that overheating is caused by vibration, you are also implying that their relation is that of a sequential event, and not a parallel one. Which means that one cannot happen before the other and both cannot be happening at the same time.
If one were to try and scratch a window glass with a knife, aren't noise, vibration and heat be generated, all at the same time, as a product of the friction??
If you were to say that "misalignment causes vibration" or "unbalance is one of the failure cause of vibration", i don't really feel the need to question it. But how can one become so sure in saying that vibration is causing overheating and implying that they are not a parallel event that are actually caused by the same cause?
Regards,
vandie
Good Answers: 444
08/10/2015 11:46 PM
That's where the concept of "causation" comes in to play, and that's why an SME needs to be consulted to verify your assumptions. Implication and inference are fine as you gather your data, but your fault tree has to accommodate all the different conditions, regardless of their source or their outcome.
For example, your conditional "...overheating is caused by vibration..." is not the only event that must be considered, you also need to examine the validity of "...vibration leads to overheating...". In fact you may discover that both events are independent of each other, but the sequence in which they occur is important.
For example, a pump may develop vibration because a piece of the impeller broke away and destroyed the balance, then the ensuing shaft vibration causes a normally smooth running bearing to start vibrating and the additional friction causes the bearing to overheat. Neither did the vibration cause the overheating, nor did the overheating cause the vibration, they were both the result of an independent event, a classic "chicken and egg" problem.
That's where an SME can help you see the interaction of all the parts of the puzzle and how they play together, something that a generic project manager is incapable of on his/her own.
08/18/2015 5:57 PM
We had a case in our plant, it was after regreasing of the bearing (roller bearing), when the equipment (crusher) started running, the bearing temperature (bearing #4) increases to 90 degrees celcius. I causes panic to the operation staff. We held a meeting trying to find the cause of the problem... but then just after two days of the equipment running, the temperature went back to normal around 70 degrees celcius on its own without maintenance team having to do anything.
The maintenance team said it was a normal thing and that it happens frequently like that, after greasing, the temperature went high for two days and then it goes down on its own...
Is it really normal something like this to happen? Why is it happening like this?
Good Answers: 444
08/18/2015 6:30 PM
Overgreasing until the excess is expelled. There is such a thing as "too much of a good thing".
08/18/2015 8:42 PM
Please explain, how can you verify that is not undergreasing, which also causes overheating?
Good Answers: 444
08/18/2015 11:50 PM
An undergreased bearing starts out hot and usually gets hotter as what little grease there is runs out/breaks down as the temperature continuous to increase; i.e., the lubricant wedge is too small/nonexistent for the load being imposed.
An overgreased bearing has the extra drag of the excess lubricant throughout the bearing contact surface, and this extra drag will cause friction which results in a rise in temperature until the grease starts to run out.
The type of bearing plays a role in the retention of grease. From this article:
"...since the ball-and-cage assembly of this arrangement does not have to force its way through a solid fill of grease, bearing heating is kept to a minimum. In fact, it was observed that a maximum temperature rise of only 20° F occurred 20 minutes after the grease reservoir was filled. It returned to 5° F rise two hours later. In contrast, the double-shield arrangement caused a temperature rise of more than 100° F (at 90° F ambient temperature the resulting temperature was 190° F) and maintained this 100° F rise for more than a week..."
Sine you did not provide a time frame for your observations I suggest that you talk to your bearing supplier/expert to see if you are really having a problem, or just perceiving one due to lack of understanding/information.
08/19/2015 1:41 AM
It's an S.K.F roller bearing. Time frame: operated first time around 2 years ago..
Reply Score 1 for Off Topic
Good Answers: 444
08/19/2015 1:16 PM
Here's 1380 pages of SKF Roller Bearings including some really good info on lubrication. It's time to RTFM (Read The Fine Manual), the free consulting portion of your 20 question session has ended.
Canada - Member - I am from Canada Eh' Engineering Fields - Mechanical Engineering - Condition Monitoring, Advanced Diagnostics and Engineering Services Engineering Fields - Aerospace Engineering - Aviation Aftermarket Services for Honeywell Aerospace
01/08/2016 8:32 AM
Just browsing through and came across this.
Vibration is an effect of a failure in some part of the system whether it is misalignment, bearing faults, poor lubrication, etc...
I could rant, but choose not to
Better to have loved and lost than spend the rest of your life with a psycho.
Reply to Forum Thread 17 comments
Andy Germany (1); Anonymous Poster (3); cspal3 (1); DrCarl (1); Fredski (1); lyn (1); RAMConsult (5); SolarEagle (1); The Green Bastard (1); Tornado (1); vandie (1)
