Previous in Forum: Pluto's Moon is Flipping Out   Next in Forum: A New F15
10 comments
Solar System
08/10/2015 12:12 AM
http://www.sci-tech-today.com/story.xhtml?story_id=013000AC9WOG#
https://en.wikipedia.org/wiki/Solar_System
More speculation outside the goldfish bowl?
Pluto has been in the news recently, and the photos show a nice spherical mass, which I find it hard to come to terms with, that such masses, are referred to as being created by odd shaped rocks colliding in space and ending up being spherical? As the mass out there referred to as the Kuiper belt and closer in the Asteroid belt; in orbit around the sun, are all moving in the same direction? So in the early stages, of the creation of the solar system, I would imagine the same would apply? So if they collided where did they get the energy to fuse into a sphere? Hence the reason for the above link to sci-tech-today, showing a large spinning mass of hydrogen, being the start of a galaxy.
So I would like to speculate that Solar systems come into existence the same way? A large cloud of hydrogen gas spinning at high speed, such that the elements of nuclear fusion take place, centrifuging out to the rim. So, to speculate further, as nuclear fusion takes place at some point on the rim it sets up a heliosphere that draws the rim elements in to a sphere as suggested in the sci-tech-link, which may or may not then explode? Causing a redistribution of heavy elements and orbital movements particularly when creating the lager planets?
Pathfinder Tags: Solar Systems Galaxys
Re: Solar system
08/10/2015 1:35 AM
Maybe I should have what you are having. The "lager" planets may have something to do with this, despite the inferiority of the beer.
Re: Solar system
08/10/2015 2:19 AM
Yes I'm half way through my glass of port. I believe the orbits of the larger (Lager)planet did move around, and for those who think this through there are some deeper implications, which I have avoided touching on? would not like to spoil your beer.
Regards JD.
Re: Solar system
08/10/2015 2:19 AM
I'm still stuck inside the goldfish bowl.
Re: Solar system
08/10/2015 2:23 AM
Re: Solar system
08/10/2015 2:33 AM
No, you're not my type.
Re: Solar system
08/10/2015 3:42 AM
Re: Solar system
08/10/2015 6:25 AM
To start with, it doesn't take energy for the odd shaped rocks to coalesce into a planet size sphere. The rocks are at a lower gravitational energy level in the final spherical form. This excess energy turns into heat.
Rock may seem very rigid, but mathematically, the larger an object becomes, the less rigid it is. It's mass (weight) increases as the cube of the size whereas the strength (rigidity) increases only as the square of the size. So on a planetary scale, solid flows like a liquid to allow the most mass to be closest to the gravitational center of attraction, which is the spherical form.
Re: Solar system
08/10/2015 8:47 PM
Yes I agree with your assessment that as mass accumulates gravitational forces take over, I think that's reasonable. But to offer up some further observations, to possibly support the argument that the mass of hydrogen, (the future Sun), accumulated heavy elements around its equator, slowly blocking off the sun rays, accumulating enough heat to initiate nuclear fusion. Therefore considering this to be the case when Venus and Mercury where being born? Could this then be considered a reason for the Huronian glaciation, and in modern terms? is the reduced light given off by the stars in our galaxy a sign that planetary systems are being born? Or the universe is dying.
https://en.wikipedia.org/wiki/Huronian_glaciation
http://www.nbcnews.com/science/space/massive-study-confirms-universe-slowly-dying-n407536
Re: Solar System
08/10/2015 9:12 AM
sometimes a cigar if just a cigar
Good Answers: 122
Re: Solar System
08/10/2015 9:39 AM
I have always thought that maybe the spinning hydrogen ball creates a vacuum that causes a broad spectrum of floating debris to be collected around the area then at some point some or all of the debris is ingested by the H2 ball.
When the right combination of hydrogen and space debris occurs, "BANG" and the mixture is solidified by the resultant explosion.
Occasionally the combination is such that the mass continues to rotate and the gasses form an atmosphere.
Fredski (1); jdretired (4); lyn (2); Rixter (1); SHOCKHISCAN (1); Tornado (1)
