Previous in Forum: A New DP Flow Meter   Next in Forum: Temperature Bath
Multispot Temp Element
08/11/2015 5:19 AM
Dear All,
For a floating roof tank light crude oil we have provided Tank level instrumentation with ( Radar level transmitter +Multi spot temp elements +Water bottom level sensor 1000 mm active length +vibrating overfill protection level switch )
I would like to know whether Water level bottom sensor will serve the same purpose as Agar Interface level probe
Regards
Jose
Re: Multispot Temp Element
08/11/2015 6:13 AM
That sounds weird. If there is any water in the tank, the bottom level of the water will be the same as the bottom of the tank. Duh.
08/12/2015 12:24 AM
Just to clarify is the Agar interface meter a brand ? Or are you talking about some nutrient gel that might be heavier than water.
As Tornado pointed out water is almost always heavier than crude oil and so will be the bottom layer and so the bottom of the water layer will be the bottom of the tank.
However if you are measuring the TOP of the water layer then yes this will be the same as the water / oil interface.
You need to be sure that the instruments can be cross referenced depending on how they measure height - differential pressure; transit time floating bobs etc
If yo have some gel / semi solid material this could be heavier than water and so be the bottom layer
Good Answers: 21
08/12/2015 4:50 AM
In your case, the bottom of the water sensor range is the tank bottom, and the top of the water level is the interface level. Suggest you re-think the question, since it is highly likely you will answer your own query...
Register to Reply 3 comments
Hilton (1); simonsd (1); Tornado (1)
