Can anyone say how spark plug gap affects engine performance? Specifically, how larger or smaller gap affects engine emissions performance--how a larger or smaller gap might make an engine more or less likely to marginally pass, or marginally fail, a state required "smog" test?
Observing that engines with high energy ignition systems are gap specified at from 0.042 to 0.046 inches (on the EPA sticker), I have noticed that plugs are sold with gaps preset to 0.042". (I determined this using a ramp-type gauge since wire gauges only measure 0.040" and 0.045"; the smaller wire will slip through the plug electrodes but the larger will not, but you won't be able to measure the exact gap with this kind of gauge.) So, would the engine be more likely to pass (even barely) at the lower gap? Or should the gap be reset to the maximum (measurable) gap or (using ramp type gauge) to an intermediate gap?
Also, which gap, larger or smaller, if either, will give longest service life of the plug?
