Previous in Forum: 20 MVA Transformer Problem.   Next in Forum: Why Have To Use Insulated Bearing in VFD Motors?
Change of Salinity Corresponds to Potential Difference
09/09/2015 9:53 AM
I have heard from my teacher in the undergrad, she said change in conductivity corresponds to an electrical potential? Is it true?
Hobbies - CNC - New Member
Re: Change of Salinity corresponds to potential difference
09/09/2015 10:01 AM
YES!
Any more questions or would you like some help in googling that question. Click here
About 5,960,000 results (0.64 seconds)
Engineering Fields - Control Engineering - Newby Member Long Time User Engineering Fields - Instrumentation Engineering - New Member
Re: Change of Salinity Corresponds to Potential Difference
09/09/2015 10:03 AM
Good teachers will teach, not just tell.
So when your instructor stated this to you, what was the reasoning that was provided to substantiate the statement?
09/09/2015 1:40 PM
Even Anonymous, ESPECIALLY anonymous posters should read the rules before asking rudimentary questions that could be easily answered by using a search engine.
14) Are there specific rules for posting?
Although you are free to post as you wish, as long as your post does not violate the CR4 Site Use Policy, we ask that you follow these guidelines when posting or commenting on CR4.
  • Look for answers before you post. Check a search engine or two to see if you can find the answer to your question or a collection of useful links. If you can't, or if the answer you find is unclear, then that's a pretty good justification for asking the question on CR4. We don't want to stifle questions, but you're more likely to get a helpful response if you've done a little research on your own.
09/09/2015 3:01 PM
Thank you Lyn!
09/09/2015 3:55 PM
09/09/2015 5:46 PM
"Electrical conductivity is a material's ability to conduct an electric current when an electrical potential difference is applied across it. It is also known as specific conductance, and should not be confused with conductance which is a property of a component, whereas conductivity is a property of the substance from which the component is made."
http://www.calculator.org/property.aspx?name=electrical%20conductivity
BDThompson (1); lyn (2); Original_Macgyver (2); SolarEagle (1)
