Previous in Forum: Open Circuit in Electric Floor Heating Wire   Next in Forum: Humming Contactors
9 comments
Motors
09/17/2015 12:26 AM
how can set a overload relay for any motor >5h.p
Re: motors
09/17/2015 1:10 AM
Read the manual!
Learn how to search the internet!
Re: motors
09/17/2015 3:41 AM
You can't.
Re: motors
09/17/2015 4:44 AM
If you don't know how, then get someone else to show you.
Good moaning!
Good Answers: 804
Re: motors
09/17/2015 5:49 AM
The only valid answer that is inclusive of "any" motor overload, is RTFM, Read The Factory Manual. Some have you factor in a pickup point, others do it for you.
Re: motors
09/17/2015 8:07 AM
factory??
Good Answers: 804
Re: motors
09/17/2015 10:21 AM
Trying to be polite...
India - Member - New Member
Good Answers: 164
Re: Motors
09/18/2015 9:39 PM
Amplifying your question - how to set (a) when the starter is DOL (b) when it is Star-delta with the relay in the line and (c) when it is star-delta with the relay being within the delta (d) when the relay is as per IEC or NEMA with a 1.15 service factor....
If someone answers, you will have a wealth of (useless) information. Eliminates the need to post on CR4 again and again.
Reply Score 1 for Off Topic
Re: Motors
09/25/2015 12:36 AM
Your question is un-understandable.
Re: Motors
11/04/2015 1:45 AM
The procedure for setting depends on the relay type. Pls specify which type of relay you are using. Lets say for 3-ph 5hp motor running on 420V ac supply, it takes around 9A current on full load, the relay rating has to be set around 11A for overload taking into 10-15% of normal current.
Crabtree (1); Electrikals (1); Fredski (1); IdeaSmith (1); JRaef (2); kvsridhar (1); lyn (1); Simon Wan (1)
