Previous in Forum: CT Burst in 110 KV Switch Yard   Next in Forum: Motor Myths
15 comments
Selecting Cable Size for 2MVA Transformer
09/22/2015 1:49 AM
I need to find the cable sizes for33kV/415V 2MVA Transformer. the current in Hv side is around 35A and the LV side is around 2800A. How I find the cables for both sides? If I select 1 Core cable for LV Side what will be the size of the same? If I select 3 Core cable for HV Side what will be the size of the same?
Re: Selecting Cable size for 2MVA Transformer
09/22/2015 2:20 AM
Pursuant to your last request for homework help, this request will also be ignored.
Do your own homework.
09/22/2015 4:55 AM
Dear Mr.chandimas,
Is it Generator Transformer or Distribution Transformer.? This point has a definite impact.
Regarding cable selection, you should not use single core cable, sincne it will get heated due to inductance. Therefore you have to use Three and Half core cable.
The LV sisde current for a PF of 0.8 lag and 415 Volts is 3478.01 Amps, where as you have referred the LV side current is 2800 Amps which indicates the P.F is higher than 0.8. and work out to 0.993, which is higher for design aspect. You have to design the cable sizing for a PF of 0.8 lag.
Take a value for current density as 0..625 Amps (for Elec.Grade Aluminium) as absolute value and multiply this 0.625 by the De-Rating factor for the cable which depends upon 5 parameters, like above the ground, under ground, Temp.Rise with in the conductor etc., etc. Devide the LV current by the corrected current density and adopt the nearest higher size. This may work out to 0.5 Amps per Sq.MM.
Hence Cable Area Required = (3478.01)/(0.5) = 6956.02 Sq.MM rounded to 7000 Sq.MM.
Considring 150 MM width and 10 MM thick Aluminium Bus Bar, youthe required Bus Bar will be (7000)/ (!50 x10) = 4.666 Bars, and the nearest higher quantity is 5 nos. and for Neutral it will be 150 x 10 3 nos. of Bus Bar to be used.
Hence you have to use 150 x 10 x 5 nos. Bus bar for each phase and 150 x 10 x 3 nos for neutral (or ) 7 nos. of 1000 Sq. MM Three and Half Core cable which ever way you want you can select.
DHAYANANDHAN.S
09/22/2015 8:08 AM
What does your local codes say about below ground cabling installed next to an active volcano?
Good Answers: 42
Re: Selecting Cable Size for 2MVA Transformer
09/22/2015 9:54 AM
I don't like to repeat myself, but in this case I propose to open the post of 09/10/2015 Cable Problem and read my notes about how to chose a correct cable.
About if to chose three_core or single_core cable it will be another problem.
In Europe for instance three_core cables are usually employed.
In spite of the currents unbalance in parallel cables is higher, the voltage building-up and the circulating shield current-if the shield is grounded both ends I'd prefer single_core cables instead of three-core cables.
The cable will be light weight and more flexible, the heat evacuation is better then the current density is higher [less number of cables per phase].It is my opinion.
Julius
Good Answers: 42
09/22/2015 10:09 AM
However, since you don't need parallel cables a 3 phases of 33/19 kV - if under fault conditions, the system would operated for a short time [1 hour or less] with one phase earthed- will be o.k. I think.
Julius
Good Answers: 70
09/22/2015 6:24 PM
You've got to be kidding (Joking)!!! Hopefully only you will be introduced to Dr. Darwin and win the top 5 Star Award and not kill anyone else or take down the National Grid!!
09/22/2015 6:36 PM
If I am right in my suspicions, and there is any justice, chandimas10 is still a struggling student.↓
Transformer Data Sheet for Design of an Auxiliary System for a Coal Power Plant
09/22/2015 9:33 PM
Cheaters get more rewards today than they ever did. Why fight it. They will have a better chance building a toaster from scratch than they ever will understanding why the answer is 42.
09/22/2015 9:53 PM
I am rapidly losing all hope for our youth.
I have never seen so many brats who feel entitled to a free ride through life as today.
We are partly to blame because we want them to "have a better life" than we did.
Unfortunately, today that means that the kids go to school till they get kicked out, then live with their parents until the parents die, then live in the house that mom and dad worked all their lives for, until it's foreclosed for lack of paying the bills.
Good Answers: 42
09/23/2015 3:05 AM
I am- sorrowfully- agree with you. However, the young fellows are not guilty, in my opinion. The reward for long training and study is very low and continuously decreases.
Julius
Good Answers: 42
09/23/2015 4:47 AM
I think will be better to use a metal-enclosed substation-switchgear connected with transformer- and use busbars in order to supply and distribute the currents.
If the switchgear is located far from the transformer in an underground run-for instance- you should have to employ 21 parallel cables of 3*300 mm^2 copper/xlpe in pvc ducts .
See-for instance:
https://library.e.abb.com/public/86ce3b71c32e5e01c1257417004c3d3c/Kline%20Switchgear%20TB%203.1.2-1B.pdf
Julius
09/23/2015 7:44 AM
Julius, was wondering whether there are some certain criteria or points to judge the the preference or necessity of busways to cables. I do know that busways are more expensive.
Good Answers: 70
09/23/2015 11:08 AM
It is wrong for anybody to supply the kid with answers !! He is in over his head and going to kill people! Screw the equipment and himself being destroyed, it people I'm worried about
Good Answers: 122
09/23/2015 6:34 PM
Consult the applicable electrical code for your site for the correct information.
In the USA the needed information will be in the NEC/NFPA tables.
Not sure about other critical details of the installation however ambient mean temperature, moisture, length, and duty cycle should be factored in.
10/09/2015 4:41 AM
Better let your electrical consultants to do all the calculation and sizing for the cables needed for the 33KV side. Don't take the risk getting some one killed with 33KV voltage.
Register to Reply 15 comments
7anoter4 (4); dhayanandhan (1); dj95401 (2); lyn (3); Mark1234567 (1); redfred (2); SHOCKHISCAN (1); Simon Wan (1)
