Previous in Forum: Box Chopper Amplifier   Next in Forum: Rotameter Float Position Sensing by Non-contact Way
23 comments
Tektronix TDS520A
10/06/2015 6:56 AM
Hi all!
I have a oscilloscope Tektronix TDS520A. Flowed capacitors, I made a mistake between 33*10V and 10*35V, and now do not know how to put. If there are owners of the same model, please send me a photo of both the boards with high resolution.
Thx
Pathfinder Tags: TDS520A
Good Answers: 109
Re: Tektronix TDS520A
10/06/2015 7:08 AM
10/06/2015 7:21 AM
Unfortunately on Tek site no manuals with circuit diagram
10/06/2015 11:52 AM
I bet their phone numbers are there. You've tried ringing them and talking the problem though with someone, haven't you? That's what I'd do, then I'm funny that way.
Good moaning!
10/06/2015 12:14 PM
The only problem there Mildred is that they are much more interested in selling you a new one than helping you fix the old one or at the very least sending it to one of their service centers ($$$).
10/06/2015 12:44 PM
Ah. Capitalism. Isn't it wonderful?
Good moaning!
10/06/2015 1:07 PM
But I'm a cheap old 8astard, so like the OP I would do everything I could to fix myself.
10/07/2015 6:05 AM
My English is very bad unfortunately
10/06/2015 10:53 AM
What do you mean by "Flowed capacitors"?
10/06/2015 11:34 AM
It's typical problem for old tektronix devices... http://www.timmestein.nl/blog/tektronix-tds-520-repair/
10/06/2015 12:59 PM
Ah, leaking capacitors. I can see how you got flowed from that.
So, you unsoldered the old capacitors from the board and forgot to mark which values went where.
Hopefully someone will be able to get you close-up pictures of the boards.
10/06/2015 1:04 PM
yes ....forgot to mark which values went where.
10/06/2015 3:33 PM
Isn't this a picture of the same circuit board you have?
It shows where which cap values go where! From the article:
"In the picture above the red dots indicate a 33uF/10V cap and the blue ones indicate 10uF/35V capacitors."
10/07/2015 4:29 AM
Yes i found this board and repaire my board but need info about second board
10/06/2015 12:49 PM
Maybe you could find something here...
http://www1.tek.com/forum/viewtopic.php?f=5&t=314
The following link could give information:
http://www.sphere.bc.ca/test/tek-parts/ ... ta-acq.doc
Good Answers: 918
10/06/2015 1:06 PM
Are you saying you may have put the wrong value cap into the board?
Are these simply filtering caps for power to the board's circuits or are these part of a signal filter?
If they are just DC voltage filter caps the real critical value would be the working voltage (WVDC). Having a little extra capacitance (i.e., 33 µF versus 10 µF) for power filtering is no problem.
I rather doubt the caps are for some form of signal filtering unless they were special high-tolerance caps.
Can you tell me exactly what they are?
10/07/2015 12:17 PM
I do not know what function they perform. Unfortunately, I took all the electrolytes and only then that they saw the two types of 10*35v and 33*10v.... I thought that only one type of capacitors 33*10V
Good Answers: 88
10/06/2015 8:02 PM
If all else fails try TekScopes Yahoo group. Some serious experts on Tek equipment there, but you must register with group to post questions. S.M.
10/07/2015 11:29 AM
I suggest you power it up and measure the voltage where the capacitor pins go. One will be more that 10V.
10/07/2015 12:27 PM
Tek used five type of voltage +5 -5 +15 -15 and 24v....I'm afraid to turn on the oscilloscope.
Good Answers: 122
10/08/2015 10:20 AM
Good thinking! To avoid creating any new issues is a very good idea.
10/12/2015 4:00 AM
Install AC capacitors and then measure the polarity of the voltage when operating. Then you can identify orientation for DC caps. If the board is in a tight space use long wires to allow the capacitors to be outside the unit for measurement.
10/15/2015 8:09 AM
Install both boards, capacitors changed but the test still fails. Check the power supply, instead of +15 volts only +3 volts.I opened the power supply, one road at 15 volts exploded. Check external power supply line rectifiers are all working well. When the power is out without load PSU down to protection mode at the output to zero. What need check in PSU?
10/15/2015 8:39 AM
I see +15 BIAS and no BIAS +12 (voltage quick changing from -12 to +12 )
Register to Reply 23 comments
Alexander (9); Anonymous Hero (1); Brave Sir Robin (2); Crabtree (2); IdeaSmith (1); LongintheTooth (1); Mikerho (3); SHOCKHISCAN (1); SimpleMind (1); SolarEagle (1); StandardsGuy (1)
