Previous in Forum: Rotameter Float Position Sensing by Non-contact Way   Next in Forum: PLC Processor's Working Memory
17 comments
Time Sync
10/08/2015 2:00 PM
There is method of synchronization of Laptop time with the International NIST time. But it is upto 1 second resolution only.
Is there any method to sync it to milliseconds ?
Pathfinder Tags: computer time
Re: Time Sync
10/08/2015 3:03 PM
Why?
Re: Time Sync
10/08/2015 3:14 PM
Good Answers: 140
Re: Time Sync
10/08/2015 4:20 PM
While I do not know where your interest comes from, one would think that the synching to your LOCAL time reference would be more important then having your local time be fully synched (to milliseconds) to a remote loaction.
Good Answers: 76
Re: Time Sync
10/08/2015 5:06 PM
No, and you wouldn't want to. Any process that requires that type of resolution shouldn't be auto-sync'ed anyway. And are you going to account for internal buss speeds and software reaction times?
However... if you let us know what you're trying to do, or accomplish - maybe we can provide a recommendation for a feasible/viable solution.
Re: Time Sync
10/08/2015 7:49 PM
Excellent answer!
Re: Time Sync
10/09/2015 1:38 AM
Please see my comment no. 8 for ... why I need it
Re: Time Sync
10/08/2015 8:51 PM
Maybe a WWVB receiver with a serial interface:
http://www.leapsecond.com/museum/ulio/m325ds.pdf
Good Answers: 445
Re: Time Sync
10/09/2015 12:46 AM
How about 200ps? "...The NIST servers listen for a NTP request on port 123, and respond by sending a udp/ip data packet in the NTP format. The data packet includes a 64-bit timestamp containing the time in UTC seconds since January 1, 1900 with a resolution of 200 ps..."
Not quite sure what good that resolution will do you unless you have a laptop running a real-time OS and you account for all the possible transmission and data handling delays, but for more information and some software go to this site:
http://www.nist.gov/pml/div688/grp40/its.cfm
The alternative is to use a GPS to access the satellite data stream for their clock data.
Re: Time Sync
10/09/2015 1:36 AM
I am looking for this accuracy, as I want to observe and record the astronomy events in the sky like occultations. The timing to milliseconds accuracy is very important to us.
In fact, I would like one step ahead, and want to time stamp the video I want to shoot. Every frame of the video should get time stamp to milliseconds accuracy.
Re: Time Sync
10/12/2015 8:18 AM
What nonsense. The earth's day varies by +/-11 milliseconds depending on which way the wind is blowing across the Andes!
Good moaning!
Good Answers: 94
Re: Time Sync
10/09/2015 4:12 AM
Atomic Clock Sync adjusts your PC time to match the NIST atomic clock, don't know the accuracy. I use another sync programme which, as far as it's display is concerned, adjusts to millisecond accuracy. The PC seems to deviate from this adjusted time quite quickly. Can't remember the name but I will check this evening.
Good Answers: 94
Re: Time Sync
10/09/2015 5:36 PM
The programme I couldn't remember is Chronograph.
Re: Time Sync
10/12/2015 1:57 PM
This also has only precision of 1 second.... not to milliseconds
Good Answers: 94
Re: Time Sync
10/13/2015 4:15 AM
When adjustment is made the time difference is displayed in milliseconds but that does not prove that the adjustment is that accurate.
Re: Time Sync
10/09/2015 8:32 AM
I found that GPS time is accurate to the second to better than 100ns but you do have to correct for accumulated leap seconds since the system was started. I think the accumulated leap seconds is currently 19. All this can be verified with a little general searching [I spent about 8 seconds]
United States - Member - New Member Hobbies - HAM Radio - AC9JZ extra
Re: Time Sync
10/09/2015 12:32 PM
Try WWV. https://en.wikipedia.org/wiki/WWV_(radio_station)
The only dumb question is the one you didn't ask.
Re: Time Sync
10/09/2015 2:02 PM
I believe that that 1 second is accurate to less than 100ns. It is a 1 second beat with less than 100ns error.
Register to Reply 17 comments
Crabtree (1); gsuhas (3); JavaHead (1); jhotmer (2); lyn (1); Mike Proctor (1); Mikerho (1); Nigh (3); North of 60 (1); RAMConsult (1); Rixter (1); tcmtech (1)
