Previous in Forum: Polarity Exchange   Next in Forum: Fire Up That Black Light, What Is It
24 comments
Good Answers: 21
I Have a Theory
10/19/2015 11:25 AM
Maybe this isn't strictly and engineering question but I thought there are many great minds here who may have thought of this and come to a conclusion. So here it is.
Let's say we have a snooker table with one ball on it and I roll it in a certain direction with a certain velocity. It will eventually come to a halt in one location at a certain time. In theory if I repeat this exactly then it will always come to halt at the same location at the same time because the initial conditions were the same and the input was the same. This would hold true for two balls, or three, or four or any number of balls.
So if we believe in the big bang, we have one set of initial conditions and the input (the big bang) happens. If we apply the snooker ball theory we could say that if the big bang happened exactly the same each time then the outcome would be exactly the same each time. So I was thinking that because the initial conditions of our big bang were set when it happened then the outcome can only possibly be one scenario.
Therefore are we living a prescripted story which was decided at the big bang. Every decision we make is nothing more than the consequence of the arrangement of atoms which has arrived at this point but was decided when time started.
This probably isn't a new idea and has been debunked already but what do you all think?
Re: I have a theory.
10/19/2015 11:29 AM
nope, once you die you're done, no second or third tries
10/19/2015 6:24 PM
How do you know this is true?
10/19/2015 11:51 AM
Nothing is ever what it is until observed, quantum theory makes free will possible...The arrow of time is a one direction trip guaranteed by entropy... $.02
10/19/2015 12:05 PM
Unfortunately, determinism is dead. Heisenburg killed it (or maybe it's neither dead nor alive, like Schroedinger's cat.) On the quantum level, it's all probability. If you play the universe over again, it won't be the same.
Good Answers: 445
10/19/2015 12:48 PM
Sorry, by that theory if you set up and release a pair of dice exactly the same every time you'll get the same result each time, something we all know is not true. Even your billiard ball theory is flawed because each time you release the ball with the same force on the same path, you microscopically change the cloth under its path, thereby altering its course a tiny bit.
I'm afraid that asking an engineering forum a philosophical question and expecting a sound result is an exercise in futility.
10/19/2015 1:02 PM
not to mention the path that the table fabric will have worn into it
Good Answers: 76
10/19/2015 1:01 PM
'If' everything is exactly the same - one could argue repeatable results even at the smallest level, but things are never the same to the degree necessary to repeat at the smallest level.
I still don't think we've been able to mathematically model the tip of a flame, or the transition from laminar to turbulent, have we? Too many variables and too many non-repeatable conditions.
Good Answers: 50
10/19/2015 1:07 PM
It's CHAOS, and there is no repeating with the exact same initial conditions. And the conditions change as they play out.
ignator -
Good Answers: 21
10/19/2015 1:35 PM
Thanks for giving it a name I could look up, determinism. Interesting topic, granted maybe not the right forum but engineering being the appliance of science I thought I'd ask.
Apparently determinism isn't dead as conflicting theories are far from complete. People I've spoken to agree that with the same initial conditions the snooker ball theory is correct but don't believe it can be scaled up to the universe, but they don't know why they think that.
I'm not saying that if we rerun the big bang the universe will be the same, as the initial condition may well be different. The problem I can't get my head around is for this big bang there was one initial condition. If there are multiple outcomes then it suggests there is either something outside the system which could influence the outcome or the snooker ball theory doesn't workwork. Assuming there is no God influencing it, where does the snooker ball theory fall down? I'm not talking about repeatability rather the idea that for a unique initial condition there is one and only one unique outcome?
10/20/2015 8:56 AM
So maybe you are onto something considering only non-living things. (planets/stars/comets) However, when you bring living creatures into the equation, can we be sure they will choose exactly the same every time? Is the thought process based on physical entities only? We still know far too little about the actual thought process to say that, for example, Hitler will attack Russia again and fail to pull out in winter. That would make a big difference in the order of things today, would it not?
Good Answers: 918
10/19/2015 2:06 PM
No. Random quantum variations play an important part in the structure of our universe.
There would be no way to insure the same set of conditions and as such, outcomes would most likely be wildly different with each throw of the dice.
This is one of the fundamental differences between the macro world (your snooker table example) and the quantum world.
10/19/2015 3:35 PM
Even the snooker ball analogy won't work, anywhere except on the equator, then only if released exactly parallel to the Earth's rotation due to the Coriolis effect.
Good Answers: 918
10/19/2015 4:31 PM
Depends on the level of accuracy you want to measure at.
The universe is another matter. A tiny deviation in anything would be huge after 13.8 billion years.
10/19/2015 6:19 PM
But if you measure it....
10/19/2015 8:22 PM
I distinctly remember distinctly remember him asking the same question 17 and a half billion years ago ago.
10/20/2015 12:12 PM
Is there an echo in here?
Re: I Have a Theory
10/20/2015 1:24 AM
Nothing stays the same; change is always occurring. Otherwise God would get bored and since we were created similar, image-wise, we have to deal with that. Randomness occurs on a quantum level and the choices we make, even unreasoned random ones are not ultimately preordained. Entropy occurs. The challenge is to try yourself to create exact same starting circumstances with your pool balls on the surface of the table on the surface of the rotating revolving planet within the rotating galaxy within the expanding universe influenced by gravity acting on all objects from constantly varying relative positions. Go on, try it. Let me know how it turns out.
Re: I Have a Theory
10/20/2015 1:28 AM
Another factor is that after the initial roll of the ball the medium through which it has to push its way will be different. The exact number of molecules of oxygen, nitrogen and other gasses will be altered, there could still be a currents that the first role set up that completely alter the second roll. In a Platonic world in theory maybe repeated roles would be possible (though I doubt it) but in the real universe initial conditions could never be repeated. Well, okay, maybe by random chance once ever 10^100 years or so.
Re: I Have a Theory
10/20/2015 5:21 AM
Have a look at chaos theory: especially the pendulum with three magnets problem.
Re: I Have a Theory
10/20/2015 9:02 AM
..there's a butterfly out there somewhere...!
Re: I Have a Theory
10/20/2015 1:56 PM
You forget that each time the snooker ball rolls on the felt, a minute amount of wear of the felt occurs, the felt is ever so slightly compressed, and subsequent rolls may take the ball ever so slightly farther each time it is rolled. That is why tables get recovered. Don't know if that would have any effect in your scenario…Intereseting thoughts...
Re: I Have a Theory
10/20/2015 2:17 PM
My take, for what it's worth, would be there's new felt each time the ball is rolled.
Good Answers: 918
Re: I Have a Theory
10/20/2015 3:44 PM
Then there is variation in the felt, lot to lot, and batch to batch.
Temperature and seismic variations and we can't forget the Moon.
Re: I Have a Theory
10/21/2015 1:27 AM
Chaos theory supporst free will. In the sense that we still dont know what is our future. But once we can predict, then chaos wont be chaos anymore.
The doctor said "just one post or reply aday in CR4, take it or leave it". I said, "what does that mean?"
Register to Reply 24 comments
Anonymous Hero (3); C-Mac (1); Fredski (2); horace40 (1); ignator (1); JavaHead (1); JE in Chicago (1); Legolaz (1); lyn (3); MACA (1); Mikerho (1); Phys (1); prof peanut (1); RAMConsult (1); Randall (1); Randy Johnson (1); Rixter (1); SolarEagle (1); Tom_Consulting (1)
