Previous in Forum: Return Bends for Pendant Type Sprinklers   Next in Forum: Lubricant Life
Small Dia. Pipe Nozzles
11/09/2015 12:51 AM
I wish to know how to protect from internal corrosion, small diameter pipe nozzles which are connected to PI's etc and those which are blinded in carbon steel vessels which are not internally coated, in Petroleum Plants" Thank you in advance.
Re: Small Dia. Pipe Nozzles
11/09/2015 9:00 AM
Then the required knowledge is that of the wetted materials, the wetting agent, its temperature and its pressure.
It is very likely that the equipment manufacturer will be able to answer this question given those details over the telephone, and this will be the most reliable and certainly the fastest route to the required answer.
Reply to Forum Thread
