Previous in Forum: Ac motor rated amps   Next in Forum: Recycle I'm already doing it....
13 comments
Knife Blades
07/26/2007 3:24 PM
I am curious if there is a "chisel like" knife blade manufactured. I have a need for a single edge razor blade with a chisel cutting edge (sharpened on one side). Any information on who might make such a blade would be SUPER!
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member Hobbies - Musician - New Member
Re: Knife Blades
07/26/2007 3:54 PM
Hi Compressor Guy,
Go here:
http://www.bentongraphics.com/home.html
I am in the coating industry and we buy these blade types in rolls. The blades we get are fairly thin (thinner than a utility knife blade), about 2-3" wide, and have the bevel only on one side. I don't know, but you may be able to get a short length sample from Benton Graphics.
Mike
"Blessed is the man who, having nothing to say, abstains from giving us wordy evidence of the fact." George Eliot [Mary Ann Evans] (1819-1880)
Re: Knife Blades
07/26/2007 4:11 PM
Mike,
Thanks for the info! This confirms, if nothing else, that this type of blade does exist.
Thank you
Ron
Re: Knife Blades
07/27/2007 1:55 AM
A real compressor guy would just
grind down a file and sharpen
works great in the right hands
LARRICAT -its better to light a lamp than curse the darkness-
Re: Knife Blades
07/27/2007 4:01 PM
Yup...half the fun is making the tools!
Amazing what you can make from one of those big fat hacksaw blades.
United States - Member - I am a Yankee Doodle Boy. Engineering Fields - Manufacturing Engineering - Old School is the best school. Safety - ESD - Safety Mgr that keeps the peace Hobbies - DIY Welding - My Motto:
Good Answers: 26
Re: Knife Blades
07/26/2007 5:25 PM
Im not sure if this would be something you would be interested in but I have a pocket knife from Columbia River Knife and Tool that I use for just about everything from gasket scraping to shaving wood, aluminum and assorted plastics. Great steel in the blade and compact yet has a very thick blade. I have the K.I.S.S. 5500 model and you can see it here.
I use it almost as much as my leatherman tool.
If necessity is the mother of invention then is laziness the mother of necessity?
Re: Knife Blades
07/26/2007 6:35 PM
I have heard of these knives before, usually being that they are very dependable. Our application is going to be on a lathe so I was looking for a more disposal blade. I am going to investigate anyways because you never know.
Thanks for your help!
Ron
Good Answers: 26
Re: Knife Blades
07/27/2007 8:12 AM
I have had mine for about 3 years have sharpened it only 4 or 5 times and it just keep on going. Best knife I have ever owned.
Re: Knife Blades
07/26/2007 10:20 PM
Hey ya Comp guy! Anything is possible! Look not towards what you want, look towards what is most economic. For instance they cleave diamonds don't they? It is a math question really. Enough mass plus momentum = result. Think!!!!
Turn a razor blade backwards and it will do your task at hand given enough thought/force.
If life is like a box of chocolates, why do I get the coffee one? That sucks!
Re: Knife Blades
07/27/2007 12:25 AM
Head for the nearest Gun show. Many of the knives you will find at a common knife table will have this "chisel" edge. I don't like them but if you find them usefull...good luck. Look for the pocket types that have a skelaton frame. Many of the ones that slide to the outside of the frame have to be like this so that the edge is shaded or protected in your pocket.
Canada - Member - New Member
Location: Richmond Hill, Ontario (North Greater Toronto Area), Canada
Re: Knife Blades
07/27/2007 2:35 AM
If you need a blade 1/4" - 1/2" wide, Xacto makes them.
You can have it good, fast or cheap. Pick two.
Good Answers: 94
Re: Knife Blades
07/27/2007 7:29 AM
I have some straight chisel edge blades about 6mm wide from this set, unfortunately there's no manufacturers info on the box or blades.
Re: Knife Blades
07/27/2007 7:46 AM
Try Zenith Cutter Co @ Zenithcutter.com
They have both standard blades and will custom fab about any configuration. What you are looking for is a common item in many of the various plastic fabrication/molding methods.
Re: Knife Blades
07/27/2007 9:53 PM
Hey comp guy; You know what? Don't waste your time, just call OLFA me thinks they are Sweeds. (prnc'). Trust me they do not want to be found short. Tell them what you need, they WILL make it. end of problem. ash
Register to Reply 13 comments
1 nut (1); Anonymous Poster (1); Ashman! (2); cOmPrEsSoR gUy (2); double_j_b (2); hip888888 (1); mikey (1); Munky (1); Nigh (1); user-deleted-1105 (1)
You might be interested in: Knife Blades, Edge Trims and Trim Seals
