Previous in Forum: Membrane Diffusers   Next in Forum: Hydraulic Valve
MOP and MAOP in ASME B31.8 for Hydrotest
01/05/2016 6:04 AM
I want to ask regarding MOP and MAOP in ASME B31.8 for Hydrotest
my question actually for pig trap (launcher/receiver) designed by ASME B31.8
in table 841.3.2-1, for onshore describe that the test pressure is 1.25 x MOP
what is MOP actually? is it only an actual operating pressure describe in design (which always less than DP)?
but in the note, it says that "If an operating company decides that the maximum operating pressure will be less than the design pressure". so MOP could be greater than DP? is MOP like MAP in ASME VIII (allowable pressure for new condition)?
it table also state that MAOP is lesser of TP/1.25 or DP (for some class)
how actually to determine this? both MAOP and test pressure is the wanted value
is MAOP the same as MOP then?
for offshore condition, the hydrotest used is 1.4 x MAOP
if refer to 845.2.2, I don't quite understand it
I think the safest value is MAOP=DP, as per that para. point (a), not less than that
could please someone enlighten me?
Re: MOP and MAOP in ASME B31.8 for Hydrotest
01/05/2016 6:11 AM
Maximum Operating Pressure [MOP] takes into account deterioration in the pressure equipment over time, and will be determined by the organisation's insurance company's Engineer/Surveyor at intervals. The MOP takes into account the wall thickness of the pressure system's materials and the likelihood of further deterioration before the next insurance examination.
MOP is always less than or equal to the Design Pressure [DP].
Maximum Allowable Operating Pressure [MAOP] and MOP are the same thing.
