Previous in Forum: Hydraulic Valve   Next in Forum: Consuming Laser Alignment with Remote Control Switch
8 comments
India - Member - New Member
Hydraulic Circuit
01/05/2016 8:21 AM
In some hydraulic circuit ,Tappo ( small dark square)is locating in pressure port 'P'.What does Tappo mean and it is the purpose of it.
When Emotions runs high ,Intellectual wont work
Re: Hydraulic circuit
01/05/2016 8:46 AM
I believe that is a tap in point, a place where you can connect a pressure device or monitor...
01/05/2016 8:59 AM
I thought he was Mr. Bojangles dance partner.
01/05/2016 9:00 AM
Or was he the dancing Marx brother?
01/05/2016 2:33 PM
It seems that somebody cannot take even an OT joke.
01/06/2016 12:29 AM
Never mind
Just jealousy what with the double-barreled score
Good Answers: 122
01/05/2016 9:08 AM
The drawing creator (draftsman) is allowed to use proprietary abbreviations.
Because of the symbol location you describe I am pretty sure TAPPO is an abbreviation for "Tapped Port".
This usually signifies a port that will accept a standard or metric threaded fitting from/for a test gauge or local indicating gauge or control device.
The port may have a back-seated valve to ensure positive shutoff and/or rerouting of the flow at that point.
The only way to be certain is to review the legend sheet or contact the company that provided the drawing.
Re: Hydraulic Circuit
01/05/2016 10:13 AM
It's Italian for cap, cork, plug, etc.
https://translate.google.com/#auto/en/tappo
01/06/2016 9:49 AM
So why is it the Italians have become the industrial machine center of the universe? Every new machine the company I work for has bought in the last 8 years has come from Italy, and apparently the OP has a machine from there as well.
Register to Reply 8 comments
Phys (1); redfred (3); Rixter (1); SHOCKHISCAN (1); SolarEagle (1); zzorb (1)
