Previous in Forum: Hydraulic Circuit   Next in Forum: Pressure Vessel Materials
Consuming Laser Alignment with Remote Control Switch
01/06/2016 2:02 AM
I came accross problem with the installation of green dot laser alignment.
The basic requirement is that there must be a laser dot alignment attached to the top of the machine and the operator must be able to switch it on from the ground via remote control.
I choose a green dot laser here:
http://www.berlinlasers.com/532nm-green-dot-projecting-laser-alignment
I was told this laser dot and power supply gets about 2.5-3m electric wires, but still not very convenient to use.Would like to know if you can propose me a few selections from your wide range that fits the requirement?
industrial laser alignment solutions
Good Answers: 181
Re: Consuming Laser Alignment with Remote Control Switch
01/06/2016 6:59 AM
Why can't you just extend the AC input line or shorten it to a dedicated outlet controlled from the ground?
01/06/2016 8:03 AM
Connect the laser power supply to a power strip like this, that you can turn on and off via a remote button. Available from Amazon for about $20.
http://www.amazon.com/gp/product/B001DF2QDK?keywords=remote%20control%20power%20strip&qid=1452085170&ref_=sr_1_4&sr=8-4
Good Answers: 26
01/06/2016 8:10 AM
What is the application?
01/10/2016 1:42 PM
Like a radio control switch controlling the laser for wireless operator control? There are plenty of options and products available.
https://www.google.co.nz/#q=radio+controlled+relay+switch
Register to Reply 4 comments
jack of all trades (1); texasron (1); TonyS (1); Usbport (1)
