Previous in Forum: Ellipsoidal Head Thickness Calculation Inquiry   Next in Forum: Allowable Stress Table For SA213-T23
9 comments
Material Equivalent
01/14/2016 5:50 AM
Dear All
Does anyone knows what is the ASME Standar Material equivalent to these 2 Chinese standard material 15CrMoG & 12CrMoVG in terms of the allowable stress? Because i need to find the Minimum Wall thickness for this material.
Any reference would be greatly appriciated.
Best Regards,
Re: Material Equivalent
01/14/2016 6:43 AM
Why not use the Chinese Standard instead?
01/14/2016 8:28 AM
Google is a great reference.
01/14/2016 11:21 AM
Ask the Chinese standard or best and accurate the manufacturer.
If I am not mistaken materials are alloy of steel, probably a stainless steel.
Site's like alibaba would perhaps give some info.
01/14/2016 4:47 PM
Done it, still found no answer.
Good Answers: 183
01/14/2016 5:03 PM
Surprizing I got the chemical composition and the mechanical properties from the first trial!
Google gave the info you want, maybe you learn how to make a research.
As for the allowable values you can make a comparison with similar qualities.
Look at european standards the form is similar.
01/14/2016 4:57 PM
01/14/2016 6:08 PM
What Chemical Composition matters when defining an equivalent material? is it the percentage of C, Mn, Cr, Mo, or all of them?.. you rarely have an exact equivalent....
01/14/2016 6:55 PM
Class is over for today.
Hint for study tonight: are you interested in chemical composition or allowable stress?
01/14/2016 7:10 PM
I Thought that if i wanted to find an representative allowable stress, i needed to find a similar material composition, and then use the allowable stress table of that material in ASME II sec D? Guess i was wrong..
Register to Reply 9 comments
lyn (3); Mr. small (1); nick name (1); PWSlack (1); Rizy77 (3)
