Previous in Forum: Material Equivalent   Next in Forum: CRAJ
Allowable Stress Table For SA213-T23
01/14/2016 6:02 AM
Dear All
Does anyone knows where can i find the allowable stress values for material SA213-T23 in order to calculate the minimum wall thickness. Because i couldn't find it in the Table 1A of ASME Sec II Part D.
Regards,
Re: Allowable Stress Table For SA213-T23
01/14/2016 6:42 AM
Yes. The material supplier knows, and is available by telephone.
Good Answers: 225
01/14/2016 6:44 AM
Does this help?
Mechanical properties for ASTM A213 T23 Low Alloy Steel
Tensile strength(min)510Mpa
Yield strength(min)400Mpa
Elongation20%
Hardness, HB220max
Permitted tolerance for OD
ODPlus tolerance(+)Minus tolerance (-)
10.29-48.30.40.4
<48.3--≤114.30.790.79
<114.3-≤219.11.590.79
<219.1-≤323.92.380.79
<323.9±1%
01/14/2016 7:01 AM
For all other ASME standar materials i worked with the entry is usually there in the table 1A ASME Sec II Part D for the allowable stress. Why is this material not inputed there i do not know... if so how can you calculate the minimum wall thickness without knowing the allowable stress at the operating temperature...?
01/14/2016 8:35 AM
<...how can you calculate the minimum wall thickness without knowing the allowable stress at the operating temperature...?...>
It is not possible to do so without that piece of data, irrespective of who tries.
Register to Reply 4 comments
PWSlack (2); Rizy77 (1); spades (1)
