Previous in Forum: Pre-Engineered Building   Next in Forum: LED as True White Light Source
Alternator
01/17/2016 8:18 AM
What is regulation of alternator
Pathfinder Tags: alternator
Re: Alternator
01/17/2016 9:13 AM
The regulator on an alternator keeps the output voltage from the alternator the same as both the electric load changes and the rotational velocity of the rotor in the alternator changes with engine speed.
Good Answers: 181
Re: Alternator
01/17/2016 9:18 AM
Click HERE
Re: Alternator
01/17/2016 11:10 AM
Voltage regulation of an alternator....
https://www.youtube.com/watch?v=VDdM6umvOLE
auto/car alternator...
https://www.youtube.com/watch?v=oxUbXtsY7cA
Re: Alternator
01/17/2016 11:27 AM
PLEASE LEARN TO DO YPOUR OWN SEARCHES.
Tips to Effective Internet Searching - Hannon Library
Re: Alternator
01/18/2016 5:01 AM
It's an excellent topic for a Google search.
Re: Alternator
01/19/2016 8:43 AM
Automatic voltage regulator or alteranator regulator stablize the generator out voltage at preset value through controling excitation current and hence magnetic flux in generator 2-the regulator in automatic mode control the generator voltage whithin +5 -5percent 3-AVR in manual mode you can set the output voltage +10. -10percent 4-in generators connected to grid AVR exclude other functions such as POWER SYSTEM STABLIZER POWER FACTOR CONTROL,REACTIVE POWER CONTROL,MINIMUM EXCITATION LIMITER ,V +/F CONTROL
Register to Reply 6 comments
lyn (1); PWSlack (1); redfred (1); SolarEagle (1); TonyS (1); yasser adham (1)
