Previous in Forum: Heating Steel   Next in Forum: Alternator
9 comments
Pre-Engineered Building
01/16/2016 4:39 AM
we have a 100mx40m PEB (pre-engineered building) . the building walls from FFL to 10ft are masonary and of steel above this 10ft masonary . guidance needed on the lightning and grounding to this steel structured PEB. any code names will be highly appreciated.height of PEB is 30ft of which 10ft from FFL is masonary. the PEB has two EOHT cranes and lighting system inside fed by 400VAC. Regards,
Good Answers: 181
Re: pre-engineered building
01/16/2016 5:39 AM
01/16/2016 7:33 AM
sri lanka is my location
Good Answers: 120
01/16/2016 8:19 AM
This is an older building? A newly built building? or one you plan to build?
Per Ardua Ad Astra
01/16/2016 8:28 AM
Then use the Sri Lanka building codes.
How hard was that.
Good Answers: 181
01/16/2016 9:19 AM
Sri Lanka codes are based on Singapore codes. Singapore is based on BS7671.
http://electrical.theiet.org/books/ £55+P&P
Good Answers: 181
01/16/2016 8:41 PM
Sorry, £85+ P&P to non members of the IET (I forgot about my members discount) I would also recommend you get the on site guide a bargain at £27 +P&P.
You will also need BS-EN 62305 (lightning systems) £230+ P&P
To put this another way, by a copy of your local codes/regulations and read and understand them.
PLEASE!
Good Answers: 153
Re: Pre-Engineered Building
01/17/2016 5:08 AM
It makes a big difference if the portal frames of your building are concrete or steel. Concrete, you bond to earth from the wall/roof sheeting and the sheeting needs to be tested and linked for earth continuity. Steel, you bond to earth from the base of each column and the sheeting fixings are usually sufficient to take care of any continuity issues. If the portal frames are steel read up on PME (Protective Multiple Earthing)
01/18/2016 5:07 AM
<Ahem>
  • Protective Multiple Earthing is simply one method of providing a safety conductor for mains electrical supply services.
  • In the UK, new electrical installations must comply with British Standard 7671 and Part P of the Building Regulations; the latter might not be applicable in Sri Lanka.
  • The Eiffel Tower in Paris is its own lightning conductor.
</Ahem>
Good Answers: 181
01/18/2016 8:37 AM
<Ahem>
UK supplies come under ESQCR-2002 (Electricity Safety, Quality and Continuity. Regulations) or BS 7430-2011COP.
Lightning systems BS-EN 62305
Neither BS7671 or part "P" building control have anything to do with electricity supply.
<Ahem>
Register to Reply 9 comments
Anonymous Poster (1); aurizon (1); coolyaar (1); jhhassociates (1); redfred (1); TonyS (4)
