Previous in Forum: Torque Required to Drill in Soil   Next in Forum: Control Valve
27 comments
Oil on AC Piping
02/05/2015 5:49 AM
I have a split dual mode air conditioner i.e heating plus cooling . the rating of a.c is 1.5Ton , 230VAC. i recently operated it in heating modes for a month without any problem . then all the sudden it stoped working in heat mode . i checked the outdoor unit and was surprised to see the one of the gas pipe from outdoor to indoor unit was covered completely in oil and grease . there are large deposit signs of oil on the soil just beneath the pipe .and even now oil is driping from it .Please guide me what is the problem.
Re: Oil on AC Piping
02/05/2015 7:14 AM
The problem seems to be either the absence of, or a reluctance to read, the troubleshooting section of the User Manual. Either that or a reluctance to pick up the phone and talk to the equipment manufacturer directly. CR4 is seeing an awful lot of that recently.
02/05/2015 8:38 AM
thank you for reminding me what the problem is.
02/05/2015 8:50 AM
Correct.
Looking back in time, one can see that the OP has consistently been one of this group.
02/05/2015 1:29 PM
Thank you too for reminding me
Good Answers: 29
02/05/2015 7:34 AM
The newer AC units include an oil lubricant with the refrigerant. You've got a leak. The oil has leaked out and likely the refrigerant as well. Call a repairman.
02/05/2015 11:30 AM
the old ones are oiless?
Good Answers: 29
02/15/2015 9:30 PM
As I understand it, the older ones, mostly the CFC's, were viscous enough that they didn't need oil. The HCFC's and newer refrigerants need oil added.
Hobbies - CNC - New Member
02/05/2015 8:59 AM
Call an HVAC technician and be prepared to open your wallet, turn it upside down and let the entire contents fall into the technicians hands.
You have a major leak and your compressor may have toasted itself.
  1. How old is the unit?
  2. What type of refrigerant (R-12, R-22, R-410a)?
  3. What type of access do you have for the tech to service the unit.
  4. From your description it appears you have what is called a "Heat Pump" which means the compressor is used for heating and cooling ($$$$$$$)
Depending on the refrigerant (R-12, R-22, R-410a) be prepared for about a $1200.00 - $1600.00 repair if you need a new compressor.
02/05/2015 10:03 AM
I purchased the a.c for $400 on june , 2013 in brand new condition . its make is "super general" . i think it is made in U.A.E . brand new compressor costs around $50. things cost low in asia.
02/05/2015 10:24 AM
So what?
02/05/2015 12:00 PM
That's a great deal. Buy a new one if it is that cheap!
02/05/2015 1:23 PM
of course i will ; if it becomes sure that the compressor has been damaged.
Good Answers: 151
02/05/2015 3:09 PM
You get what you pay for
02/05/2015 4:55 PM
So very true.
02/05/2015 10:13 AM
The refrigerant is R22.its weight is 1.430kg.
02/05/2015 10:25 AM
And?
Good Answers: 266
02/05/2015 9:03 AM
Other have pointed to the oil coming from the refrigerant. Another possibility is what you have may be a heat pump. It may have worked fine as a heat pump. It has got colder and may have called for auxiliary heat. What type of auxiliary heat the unit uses is in question. If it does use fuel oil. You may have a leak. This leak could have caused the shut down. Easy to tell smell the oil. Fuel oil has a distinctive odor.
02/05/2015 9:58 AM
The fuel smells like the engine coolants of car. i am not an expert of oil odors,so cannot exactly tell .
02/06/2015 12:25 PM
I am an expert of the smell of threads.
This one stinks.
<unsubscribes holding nose>
02/06/2015 9:48 PM
LOL!
"When I thought I exceeded to be wise but wisdom was far from me" -King Solomon
02/07/2015 10:55 AM
Change ur diapherz then
Good Answers: 266
02/09/2015 4:28 PM
So you don't know if you by fuel oil or not?
02/05/2015 9:10 AM
Heat pump and cooling unit is shifted by the use of a valve exchanging condenser and evaporator unit for cooling and heating. Fault might be due to failed oil separator down stream of condenser(which ever is used) or wet line resulting to total mixture of refrigerant and oil at expansion valve and evaporator. Definitely, one could tell oil was first solidify at evaporator by the time oil separator fails then the bursting of the lines follow at high pressure side.
02/05/2015 11:29 AM
you have a refrigerant leak, call a pro
02/05/2015 12:33 PM
You have a leak.... Call a pro
02/05/2015 9:35 PM
I dont know why you even ask!
While electric appliances let the magic smoke out when they die it is different with the AC units which will let out smoke and fluids. You need to look if the smoke is out too.
Other than that:
You have a leak, call a pro!
02/06/2015 1:58 AM
If it is Heat Pump model please check the functioning of reverse valve . if it is an ac with heaters on it check the oil leak in condensing unit in consultation with the units trouble shooting manual.
Register to Reply 27 comments
coolyaar (7); Fredski (2); gringogreg (1); IdeaSmith (1); Kulas (2); Lo_Volt (2); lyn (2); mrswamy (1); Original_Macgyver (3); ozzb (2); PWSlack (3); SolarEagle (1)
