Previous in Forum: TCC Curve   Next in Forum: Fuel Cells
20 comments
Voltage Stabilizer
03/26/2013 7:00 PM
In our domestic single phase 230v system,the voltage drops as low as to 120v making it impossible to use appliances. i searched the market and found voltage stabilizers with rating of 4000 watt and input from 80 to 250v and output 230v . it the voltage specs are clear but what does the 4000 watt mean on the stabilizer.does it mean we can use this stabilzer for a load of 4kw. help please.
Re: Voltage stabilizer
03/26/2013 7:11 PM
Where are you located?
03/26/2013 7:17 PM
He's located in La La Land.
Re: Voltage Stabilizer
03/26/2013 8:09 PM
What do YOU think it means.
Come on now, what have we told you about performing a simple internet search and reading the manual.
03/26/2013 10:25 PM
Fix the loose connections.
Good Answers: 21
03/27/2013 3:31 AM
It sounds as though you are in a country that has issues with the power grid. If so there is not much your going to do to improve the end product. I would offer this advise; pick up a generator unit that will supply the needed power at the voltage you need it, until the power company fixes their issues.
03/27/2013 4:01 AM
Dear Mr. coolyaar,
The answer is YES. When Input and Output Voltage Range is given along with WATTS, THE CAPACITY is 4.0 KW. It appears to me me that the voltage Stabilizer is 5.0 KVA.
My view is Input Voltage Range of 80 to 250 Volts appears to be very large.
DHAYANANDHAN.S
03/27/2013 4:53 AM
If the supply isn't capable of supplying 4kW without voltage drop, then adding a voltage stabiliser isn't going to improve matters.
The issue is that the supply cables are undersized. Get onto the power supply company and have a commercially expletive moan.
03/27/2013 5:42 AM
both the answer from dhayanandhan and PWSlack are correct. if you ask about capacity of the voltage stabilizer, it is 4 kW which means you can have it loaded for 4000 watt but if your main power supply is less than 4 kW you can't have it loaded
Good Answers: 69
03/27/2013 9:50 AM
Have the main supply lines checked by the power company, if the voltage drop occurs within your property, you're risking your house to a nasty fire, if it occurs outside, you're probably setting things up for a sudden meltdown of the power lines, which can lead to electrocution risk for pedestrians if it's located at the primary of the step-down transformer.
This is serius stuff, don't buy any stabilizer to "correct" this !!
03/27/2013 12:09 PM
Dear Mr. Yahlasit,
You have mentioned - a VALID and IMPORTANT Point, and Thank you for the same. I replied only from Tech. Point of view, but working aspect did not strike to my mind.
I have NOTED DOWN your Point.
Thanks,
DHAYANANDHAN.S
Good Answers: 69
03/27/2013 5:00 PM
You are wellcome Dhayanandhan, what may come before safety ? common sense.
Regards
Good Answers: 32
03/27/2013 10:45 PM
I really get the feeling that if you attach a voltage stabilizer to a 230 VAC power source that is dropping to 120V, whatever the reason for the voltage drop will become painfully and dangerously obvious. I think it would be a much better idea to fix the source of the problem.
johny451
03/28/2013 5:17 AM
Do your neighbours also have the same problem? If so it is very unlikely that it is something on your property that causes the voltage to drop.Get all your neighbours to combine and then go to the authorities. There is strength in numbers.
Using that stabiliser could keep you comfortable as long as you draw less that the designed power output of the unit. (<17 Amps if it is a single phase supply).
Good Answers: 122
03/28/2013 9:01 AM
Be careful.
Allthough the stabilizer is rated for 4KW you must determine if the rating is for continous or intermittent usage as dictated by the "duty cycle" rating.
For instance:
A maximum KW rating of 4KW at a 40% duty cycle usually means the 4KW would only be sustainable for 40% of 1 hour = 24 minutes.
The amount of KW sustainable after this point is dependent on the quality of the stabilizer components and usually decreases substantially.
A graph and/or table should be available from the manufacturer that illustrates all of the values and information you will need to know.
03/28/2013 9:14 AM
First thing to check is your neutral good, if its bad, voltage could flux from 40 to 200 V. It could be bad at wheatherhead from bird dodo or water damage inside meter or if basement damp in panel. device you are proposing to use is for single appliance and can not be used to install on buss for multiple as it has no neutral - CAUTION - . Some 230v appliances have 120v controls so could not be used.
The 4000 is amp/heat rating of stabilizer. With motor load and normal power-factor = 5 hp or it may operate a resistive heater with no power-factor up to 5000watts.
Yes 4000w is 4kw.
03/28/2013 9:41 PM
Yes, You can load it up to 4KW, but act as per duty rating.
03/31/2013 10:54 AM
The 4KW rating means any combination of volts x amps will total 4KW.
Mr.Ron from South Ms.
04/02/2013 8:27 PM
Before you buy a stabilizer, I recon you check your main service cable, terminations/connections at the entrance box, your fuse connections, metering connections, and the distribuiton board connections.
"Whatever your mind can concieve, and believe, it can achieve"...Napolean Hill
04/03/2013 1:38 AM
I have seen 160 volts instead of 230 at peak hours of consumption, but 120 is quite low. Looks like the distribution transformer is some kms away from you. Give an application signed by many, to the concerned authority for installing a transformer nearby.
Gajanan Phadte
03/20/2014 4:03 AM
Domestic single phase of servo voltage stabilizer is available in standard fluctuation range of + 20%. All models can be factory preset for any output voltage from 215 to 240V P-N. standard protections include overload & short-circuit protection.
http://www.tsielecpower.com/indoor-automatic-voltage-regulators.htm
Register to Reply 20 comments
Anonymous Poster (1); bolang (1); dhayanandhan (2); fixitorelse (1); gmphadte (1); jack of all trades (1); jennifermethow (1); Joel Helms (1); Johny451 (1); nick.mapun (1); pillay (1); PWSlack (1); ronseto (1); SHOCKHISCAN (1); Tornado (1); wareagle (1); Yahlasit (2); zs6bli (1)
