I am trying to find a normally open cable actuated electrical switch. I need for the switch to be capable of actuating at 400 to 1,400 lbs. cable tension and be able to provide approximately 10 amps at 110 volts alternating current. The switch would be set for the actuating tension at installation, then left at the given level. It needs to be non-locking such that when the tension is reduced the switch opens. My searches keep finding normally closed cut-off switches. Does anyone have a source for such a switch?
