Previous in Forum: How Do VFDs Work in Pumps?   Next in Forum: Tubing
13 comments
Upstream Pressure of Orifice
01/24/2016 6:33 AM
What is relations between upstream pressure and flow of orifice .
Pathfinder Tags: orifice
Re: upstream pressure of orifice
01/24/2016 8:06 AM
Good Answers: 120
Re: Upstream Pressure of Orifice
01/24/2016 8:24 AM
The pressure is higher upstream, varies with the pressure, varies with the diameter of the aperture, varies with the viscosity of the material in the fluid state, and to some degree with the temperature. Not suitable for non newtonian materials(except in special cases), nor thixotropes below critical shear.
Apertures are calibrated to a fluid by measurement over a range and used with a measuring method, such as a manometer or pressure gauge.
From the above, derive the equation of volume flow....
Per Ardua Ad Astra
01/24/2016 8:34 AM
I thought this was already covered in chapter 4 of your textbook.
Good Answers: 120
01/24/2016 8:41 AM
Student daze...
Per Ardua Ad Astra
01/24/2016 9:37 AM
01/24/2016 12:00 PM
I don't know, but I bet your textbook does. Why don't you just look it up, Mildred?
Good moaning!
01/24/2016 4:23 PM
Maybe it is a trick question, with the answer "none", since flow depends on differential pressure rather than upstream pressure alone.
Good Answers: 61
01/24/2016 6:28 PM
Oh dear, I can think of some really funny answers to this.
01/25/2016 8:15 AM
Thanks for answer Suppose an orifice is designed at 8 bar upstream pressure but now upstream pressure is 4 bar , so what is effect on flow.
Good Answers: 120
01/25/2016 8:42 AM
https://en.wikipedia.org/wiki/Orifice_plate
Per Ardua Ad Astra
01/25/2016 9:24 AM
It seams to me that you do not understand the difference between differential and absolute pressure. Also since 1 bar is so close to nominal atmospheric pressure, one should not dismiss the effect of atmospheric pressure. You've have been given links to orifice flow metering already. This implies to me a reading comprehension deficiency.
Good Luck in your future schooling efforts, either formal or self taught.
01/25/2016 2:15 PM
It will be less, but the given information is insufficient to tell how much less.
01/25/2016 9:37 PM
The basic principle of the relationship of DP to flow rate is explained in this thread:
http://cr4.globalspec.com/thread/72991/Flow-Transmitter-Range
The numbers are different, (flow is approximately doubled, not DP), but the concept is there, along with a link to a tutorial.
Register to Reply 13 comments
aurizon (3); Carl_E (1); Crabtree (1); dharam_ver9 (1); energyconversion (1); lyn (1); redfred (2); Rixter (1); Tornado (2)
