Previous in Forum: Steam Requirement for Textile Dyeing Machine   Next in Forum: Engine Runs without Air Supply
12 comments
Power Plant Question
02/20/2016 12:01 PM
My company will be water washing the economizer tubes from a #2 oil fired boiler to get some heat transfer recovery. I believe I will end up with a dilute acid water that I will use bags of soda ash to neutralize. I have ph paper as a guide. I dont know how much soda ash to buy as we have never done this type of wash. Anybody out there have any experience with this? I estimate 100,000 gallons of acid waste water to be treated.
Re: ENGINEER AT A POWER PLANT
02/20/2016 12:45 PM
I imagine it would be hard to estimate this very closely, even if the soot thickness were known (and which might vary quite a bit). How about using a bag at a time, measuring the pH each time, and getting a trend?
02/20/2016 12:57 PM
Thanks, I don't really see a lot of build up of soot with the oil we are using. I was thinking of doing titrations in the lab to stay ahead.I have to buy all the soda ash 1 week ahead so planning of quantities is important. I would like to overbuy and store than not buy enough.
03/05/2016 12:12 PM
Hello everyone
We finished our 5 day economizer wash of two boilers. The ph was not an issue---close to 7.0--Used one bag of soda ash but probably not even needed. Turbidity was a bigger issue and we had to use a bag of Z-TAG polymer that was listed on our permit to take out the ash.
02/20/2016 1:55 PM
I'd do a 10 lbs trial, get your data then attack
02/20/2016 3:39 PM
That sounds like a good idea.
Re: Power Plant Question
02/20/2016 4:06 PM
According to my calculation you need ~ 3.5 lbs to raise each .1 ph...
I'd say black coffee....so about 70 lbs....give or take
02/21/2016 1:45 AM
If you have a competent lab staff capable of performing titrations, they can do a much better job of advising you than guestimates from here.
pH=7 will do fine for telling you when you are at neutral, at the time of testing.
If you can long-term store the soda ash, overbuy. It can't be very expensive.
100,000 gallons seems like a nice round number. Hope you're not hoping for a number from here to scale up or down.
03/08/2016 5:27 AM
Hi there
Used to have a staff-now its no one! We used a bag of the soda ash sitting around. The ph was the issue but turbidity was so we added a bag of polymer to settle it out.
02/22/2016 3:44 AM
It depends upon a lot of factors, such as the nature and strength of the acidity in the wastewater and the discharge consent limits applicable, which haven't been stated.
pH paper is a rather crude indicator; it would be better to use some sort of calibrated instrument so that when the utility requests traceability of the effluent, it can be provided.
03/08/2016 5:40 AM
We neutralized in a small pit upstream of the final discharge. There is a turbidity meter and ph indication on the final effluent.
05/17/2021 3:27 AM
Wonderful. Do let the forum know how it all went.
Good Answers: 181
02/22/2016 7:07 AM
Correcting the pH value is only a minor problem. What do you intend to do with all the nasty residues that will accumulate?
In a similar situation we lost the effluent over a 5 month period by adding it to our process water.
Register to Reply 12 comments
Carl Berkman (4); Fredski (1); lyn (1); PWSlack (2); SolarEagle (1); TonyS (1); Tornado (1); zzorb (1)
