Previous in Forum: Synchronous Generator Question   Next in Forum: Isolator between VFD and Motor
9 comments
Control Engineering Question - What Drawback is Associated with Gain Compensation?
02/23/2016 9:38 AM
Hi, I need to revise for an upcoming test but I cannot find the answer to the question - What drawbacks is associated with gain compensation?
If you can help it would be cool
Pathfinder Tags: Control Gain Electrical
Good Answers: 445
Re: Control engineering question - What drawback is accosiated with gaincompensation
02/23/2016 9:47 AM
CR4 is not a homework help site. It would not be "cool", but instead a disservice to your engineering education, so go back to your Control Systems 101 textbook, clearly you have not looked at it yet.
Engineering Fields - Control Engineering - Newby Member Long Time User Engineering Fields - Instrumentation Engineering - New Member
02/23/2016 10:00 AM
Here's my answer for you.
What's the list that you've come up with so far?
Give us something to evaluate your understanding of the question.
02/23/2016 10:03 AM
I think I have it now, The drawback is that it has a slow response
02/23/2016 11:03 AM
Okay. Now you get to justify that statement.
Is a slow response what you would expect?
What's the advantage to a slow response?
Would you rather have a fast response?
What are your other "answers" for the original gain compensation question?
11/04/2019 7:13 AM
How did you come to this conclusion? what reference material did you use?
Looking at same question but don't have textbook stated in post.
02/23/2016 12:42 PM
That's cool...but you need to formulate your own answer...
https://en.wikipedia.org/wiki/Automatic_gain_control
Good Answers: 42
02/24/2016 10:46 AM
AGC - That brings back memories...
We had a small airplane and the noise level was intense.
I played around with headsets and noise cancelling microphones - that helped a lot.
Then I added AGC, but also needed squelch to kill the background when no one was talking. Almost made conversation bearable. Tended to have a small delay before the squelch would release so you tended to start every sentence with "Ummm".
Re: Control Engineering Question - What Drawback is Associated with Gain Compensation?
02/23/2016 8:03 PM
Once you start gaining and it gets compensated, so the gains are not as high, you will not gain enough, maybe, which is a drawback.
Sure there is literature out there that explains this!
02/24/2016 9:39 AM
Is "gain compensation" bean counter related? Power systems, may be?
Register to Reply 9 comments
BDThompson (2); derekb (1); GW (1); IdeaSmith (1); Mr. small (1); nathan27th (1); RAMConsult (1); SolarEagle (1)
