Previous in Forum: Dimming an LED System up to 150' Away on 0-10V   Next in Forum: Control Engineering Question - What Drawback is Associated with Gain Compensation?
Synchronous Generator Question
02/23/2016 4:29 AM
Hi everyone
What is the position of rotor north pole w.r.t conductor when induced emf in the conductor is at the peak in the synchronous generator.
Consider the terminal is shorted.
Re: Rotor position of a synchronous generator when emf induced in a conductor is pea
02/23/2016 5:52 AM
02/23/2016 7:02 AM
If the terminal is shorted, then the emf is zero, therefore the pole's position is irrelevant.
One hopes that the generator's protective equipment can operate to disconnect the fault before any damage is done.
Re: Rotor Position Of A Synchronous Generator When Emf Induced In A Conductor Is Pea
02/23/2016 8:39 AM
42.
Good Answers: 445
02/23/2016 9:41 AM
It's a good question for a quiz or an interview. How did you answer it? For more information consult your AC Machines101 textbook (hint- none of the above).
Good Answers: 181
02/23/2016 9:48 AM
Do your own homework
Re: Synchronous Generator Question
02/23/2016 8:08 PM
I know!
It in the North! (would other wise not be the North pole!)
IDNWYATA!
02/24/2016 10:07 AM
Homework again?
Register to Reply 7 comments
Andy Germany (1); IdeaSmith (1); lyn (1); PWSlack (1); RAMConsult (1); SolarEagle (1); TonyS (1)
