Previous in Forum: Stator Winding   Next in Forum: Repair of Cracks in Rotor Bars of 3.3 Kv 500 kw , 40 years Old
Regulation
02/29/2016 6:22 AM
Regulation of over headline is the difference between sending end voltage and receiving end voltage This is because of voltage drop in line and any fault.The regulation is high because the resistance is amall
Re: Regulation
02/29/2016 6:46 AM
Ok, lets discuss this.
If this is what your text book says you are right.
If this is not in the text book like this, then it maybe wrong or falsely interpreted.
As per discussion the statement is wrong, as the regulation can not be a difference.
Re: Regulation
02/29/2016 8:52 AM
...and?
Re: Regulation
02/29/2016 10:26 AM
Sounds like Ohm's law to me.
Good Answers: 42
Re: Regulation
02/29/2016 11:33 AM
Wikipedia:
"In electrical power systems it is a dimensionless quantity defined at the receiving end of a transmission line as:
Percent VR=(|Vnl|-|Vfl|)/|Vfl|*100
where Vnl is voltage at no load and Vfl is voltage at full load. A smaller value of Voltage Regulation is usually beneficial."
Julius
Good Answers: 42
Re: Regulation
03/01/2016 6:58 AM
According to IEEE 141[Red Book] :
If |Vnl|=es and |Vfl|=eR then Percent VR=actual voltage drop/eR*100
An elevated R or X [or both Z] produces an elevated VR.
An overhead line presents a bigger X[reactance] due to increased distance between conductors.So a more elevated voltage regulation.
Julius
Good Answers: 42
Re: Regulation
03/01/2016 7:10 AM
Sorry!
Julius
Register to Reply 6 comments
7anoter4 (3); IdeaSmith (1); PWSlack (1); Rixter (1)
