Previous in Forum: Earthing System for HV Sub-Station 132kV   Next in Forum: Regulation
15 comments
Stator Winding
02/29/2016 1:47 AM
I work in a power station.We have 175 MW generators installed.Recently faced a problem in which there is a whitish powder on the stator bars just at the entrance of the stator core/slot.Picture are attached.Can any one give reason. I feel it may be ageing(units installed in 1982). Also what remedial measures should we adopt
Good Answers: 181
Re: Stator winding
02/29/2016 3:45 AM
A change in the environment local to the generator is where I would look first. From the photographs the "white deposit" doesn't look like it originated from inside the windings so something external would be the logical culprit.
Look for something that has been placed in the local of the cooling intake.
Baldor-Reliance published a white paper on the effects of localised pollution.
Re: Stator winding
02/29/2016 4:41 AM
i agree that surroundings will have its effect.but then it should be on all bars and not few
Re: Stator winding
02/29/2016 6:43 AM
Some guessing:
  1. Its solidification of the white smoke that when it comes out of the appliance, the appliance (mainly electrical) does not work anymore
  2. What material is the stator bar? Any coating? If so is there an oxide in existence that is white?
  3. Are there any vermins?
Good Answers: 266
Re: Stator winding
02/29/2016 7:42 AM
Here is some info on problems with windings. The heavier deposits appear where the insulation has broken down. It may be the junction of where two different insulators were used. One on the winding where it passes though the slot may be deferent then whats on the rest of the winding.
http://www.irispower.com/pdf/techpapers/general%20testing/recent%20problems%20experienced%20with%20motor%20and%20generator%20windings%20-%20IEEE%20PPIC%20-%202009-06%20sep%202009.pdf
Re: Stator winding
02/29/2016 7:55 AM
Good Answer!
I would also suggest analyzing the cooling gas (I am assuming hydrogen). If there is oil vaporizing in the cooling gas from the seals this could be deposits from it.
Drew K
Re: Stator winding
02/29/2016 8:53 AM
Did some animal of some sort enter the enclosure, the white powder being its cremated remains?
Re: Stator winding
02/29/2016 10:14 AM
Are those water cooled windings?
Drew K
Good Answers: 445
Re: Stator winding
02/29/2016 10:37 AM
I would take samples of that powder and have it analyzed to know exactly what it is. My guess is that it's mold, which could from a few sources. If the unit was out of service for an extended period without an inert gas blanket, the unit was left opened in a high humidity environment without any keep-warm heaters, or you have have a water leak in the cooling system.
To remedy the situation you need to first determine the nature of the contaminant, then track down the cause(s). If you want that machine to last another 34 years it needs extensive and complete testing to determine the level of insulation integrity since there is clear evidence of cracked, peeling, and questionable end turn insulation.
When it has been professionally inspected and evaluated, then you can decide if the needed work is economically justifiable.
Re: Stator Winding
02/29/2016 11:47 PM
The unit is air cooled.The air being cooled by water in surface air coolers.The black tape is the anti-corona taping.inside the anti corona taping is the mica and glass taping.The megger,Ductor results are normal
Re: Stator Winding
03/01/2016 11:09 AM
The more that gets added, the closer the solution. To speed things up next time, it is best to make sure all the relevant information is in the original posting as readers here have better things to do than play "20 Questions" games.
Re: Stator Winding
03/01/2016 7:24 AM
White powder in HV Electrical equipment could be caused by partial discharge.
Re: Stator Winding
03/01/2016 11:35 AM
Is it dusty, coarse, fine, thick, thin, loose, their by gravity, easy to remove by light brushing, or engrained needing a wire brush or sandpaper. And if brushed away what it the 'clean' surface like? pitted as if corrosion, or like new when wiped - Is it 'salty' ....etc, etc...?
Not that I could say what it was if you told me. But others might know.
Good Answers: 42
Re: Stator Winding
03/01/2016 12:50 PM
Test the composition of the "powder" - It may be fungal / mould, or it may be corrosion on the metal parts above the windings dropping onto them.
External contamination may also be possible - trace the path of the deposits.
Let us know what you find.
Re: Stator Winding
04/02/2016 5:32 AM
As suggested by Mr. Ram, get the "powder" analyzed. It could be powder from end winding braidings. If the braids become loose, they may disintegrate into powder. Check the end winding clamping system for any looseness, looseness of the winding bars in stator slots, especially end wedges. Are there ripple springs below the slot wedges? What type of winding insulation is it? Glass Epoxy? In that case, loose winding bars may hammer the core slots due to bar vibrations and insulation may appear in the form of powder. Were the winding vibrations normal before the appearance of powder? Look into all these aspects and coma back.
Re: Stator Winding
09/19/2016 2:05 PM
I think the insulation layers have deteriorated at the line of stress grading (if there is) and the semicon layer. When it is not working properly, it overheats and produces PD's.
What was the reason? Did you tested the white dust?
Register to Reply 15 comments
Drew K (2); GW (1); horace40 (1); IdeaSmith (1); jan63 (2); ozzb (1); pcchatur (1); PWSlack (2); RAMConsult (1); ticker (1); TonyS (1); Tremer (1)
