The chamber has been experiencing random temperature control shutdowns with
just as random recovery, or with a lab tech power cycling to reset the
system.
We had assumed that it was an issue with the control relays again (1 was repalced 2 years ago - arc welded contact - so replaced all three) but they were not the root cause. (the new relays are more robust)
The unit is circa 1995, uses a watlow 985 controller and a Watlow 160[?] Transmitter board for the sensors.
I am thinking it may be either the under or over temp contactors but I dont know refrigeration systems well enough to speculate.
Right click to open diagram in a new window.
