Previous in Forum: Rust Removal Using a Laser   Next in Forum: Solar Eclipse
31 comments
What is It?
03/08/2016 2:10 PM
Re: What is It?
03/08/2016 2:26 PM
Hi-tech guillotine or stocks and pillories?
Re: What is It?
03/08/2016 2:28 PM
can you demonstrate?
Re: What is It?
03/08/2016 2:52 PM
Ship it Maryland. I'm sure I can find some inside the Beltway who would be appropriate subjects for said demonstration.
Re: What is It?
03/08/2016 2:33 PM
The best nutcracker you can buy.
Re: What is It?
03/08/2016 4:32 PM
correct
Good Answers: 266
Re: What is It?
03/08/2016 2:38 PM
The bottom look simular to a press once used to press new tires on the rim on a fork lift.
Though you don't need a computer to do that. So the bottom is a compression tester.
The top tension?
Re: What is It?
03/08/2016 3:45 PM
An even more complicated way to make fire?
Good Answers: 151
Re: What is It?
03/08/2016 3:47 PM
Used to measure compressive and tensile strength of materials
Re: What is It?
03/08/2016 6:37 PM
That's what I'd go with
Re: What is It?
03/08/2016 7:34 PM
and...https://www.youtube.com/watch?v=bn3dz5HC164
good for columns in strike slip prone areas
Re: What is It?
03/09/2016 12:07 AM
AHH, yes! They were fun, especially when we encountered one that a 'pranky' contractor slipped a piece of rebar into before it cured. POW!!!
Robert A. Heinlein (1907-1988) "There is no worse tyranny than to force a man to pay for what he does not want merely because you think it would be good for him."
Good Answers: 145
Re: What is It?
03/08/2016 4:04 PM
Re: What is It?
03/08/2016 4:27 PM
We had an Instron in a lab I worked in.
As gringogreg said, it tests tensile and compression of materials.
Good Answers: 151
Re: What is It?
03/08/2016 4:29 PM
Besides its intended use, it can be used to pull the cork out of a wine bottle, and then push the cork back in if you don't finish the whole bottle.
Re: What is It?
03/08/2016 4:47 PM
We used ours once to stretch the bosses 6 inch steel scale about 1/16-1/8 inch.
After patiently waiting for a few weeks, we called him over to settle a discussion on the length of a plastic part.
I measured it with my scale and gave it to him to measure. His reading was higher than mine. I called him out and gave the part back to him. He measured it again and proclaimed he was right and I was wrong.
Out came the calipers and we handed them to him. Needless to say, he was dumbfounded.
In the end we all had a good laugh. Him too.
Re: What is It?
03/08/2016 7:51 PM
"His reading was higher than mine".Should have been: His reading was lower than mine.
Good Answers: 73
Re: What is It?
03/10/2016 12:08 PM
I'll bet you could sell those as a gag gift!
Re: What is It?
03/08/2016 4:50 PM
or hang connecting rods on pistons
Good Answers: 94
Re: What is It?
03/09/2016 4:57 AM
I must try that, if I ever have a bottle that is not finished.
Re: What is It?
03/09/2016 6:35 PM
What is this don't finish thing your refer to???
Re: What is It?
03/10/2016 8:17 PM
Sorry I do not understand this concept of not finishing a bottle of wine.
Good Answers: 94
Re: What is It?
03/11/2016 4:08 AM
I think it's an urban myth, like those 'sharing' packs of sweets or crisps.
Re: What is It?
03/08/2016 4:39 PM
I believe this instrument tests tensile and compression failure strength of materials.
Re: What is It?
03/08/2016 7:28 PM
Re: What is It?
03/08/2016 7:36 PM
A machine to test how hard it is to break stuff?
Re: What is It?
03/08/2016 7:42 PM
Re: What is It?
03/09/2016 2:10 AM
Universal Testing Machine for materials / hydraulic,,,,, CHT4000 Series.
Re: What is It?
03/09/2016 12:25 PM
I see a very elaborate press for setting a bearing into its enclosure by lowering the top section to the base. But there may be a less expensive hydraulic press that would suffice.
Re: What is It?
03/09/2016 12:29 PM
The CIA used this a Gitmo to extract answers from terrorists by telling them it was a brain scan that would read their thoughts, so they might as well talk now and avoid the crushing pain when their brains were "read".
Good Answers: 179
Re: What is It?
03/09/2016 6:52 PM
Sir Robin is very close.
It's actually one of Emperor Barry's FEMA Guillotines for snuffing out Patriots.
It somewhat looks like a concrete compressive strength testing apparatus.....for breaking concrete cylinders.
Re: What is It?
03/09/2016 9:47 PM
A hamburger patty maker for the $25 burgers at Planet Hollywood?
Register to Reply 31 comments
bluebelly (1); Brave Sir Robin (2); BruceFlorida (1); CaptMoosie (1); Fredski (6); gringogreg (2); I.L.M.E. (1); lyn (3); Nigh (2); NotUrOrdinaryJoe (1); ozzb (1); phoenix911 (1); Randall (1); redfred (1); Rixter (1); Sid_Sidow (1); simonsd (1); tcmtech (1); wayneelowe (3)
