Previous in Forum: BAC net   Next in Forum: Steel Wire Rope Manufacturing - Feasibility Study!
Pumping volatile liquid high pressure
07/31/2007 8:17 AM
I have a client that needs to pump SHELLSOL D60 for test stand. It has a .763 specific gravity at 15.6 C and a 61.1 C flash point. Conditions are 18 USGPM at 1050 PSI and 75 USGPM at 170 PSI. We are a pump supplier but have nothing for this application. Location: Detroit, MI USA.
Thanks,
Joe T.
Inga Binga Bunga Banga Boonga Binga Buuuunnnnga
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
Re: pumping volatile liquid high pressure
07/31/2007 8:40 AM
It probably wants a hazardous area motor, just to be on the safe side. Looks like about 17kW.
Essex jobs for Essex yobs! <Burp>.
Re: Pumping volatile liquid high pressure
08/01/2007 3:54 AM
Diaphragm pumps have been used to pump nitroglycerine, so you may wish to concider the following pumps:-
18/1050 -One x D35 Hydra-Cell Pump from Wanner Engineering, Inc.
75/170 - Two x H800 Wilden Pumps.
Good Answers: 94
08/01/2007 4:47 AM
When I worked for a company that made control valves I sent a sample toggle switch to a customer who wanted to pump nitroglycerin, I never heard from him again & often wonder what happened.
We also had a stainless valve returned because the PTFE seals had degraded, the customer was pumping boiling radioactive nitric acid!!! It was the radioactivity that killed the PTFE.
Good Answers: 19
08/01/2007 10:01 AM
Google "Metering Pumps" SS Diaphragm likely.
08/01/2007 10:16 AM
Last I checked this is what you would call charcoal lighter fluid.
Typ use double mechanical seal, Cl1 Gr D div 1 motor.
Any major pump mfg could provide.
Good Answers: 19
08/05/2007 2:51 PM
High pressure fuel pumps are common for oil-fired boilers. Maybe you look up Danfoss Fuel Pumps . They might be carrying a pump for your application.
08/09/2007 2:16 AM
Easy
Call me at 800 862 4328 Tom Silver.
Register to Reply 7 comments
Anonymous Poster (1); ducon (1); fliptop427 (1); Nigh (1); Paddler (1); PetroPower (1); Stinky Pete (1)
