Previous in Forum: A Scrap It or Fix It Conundrum   Next in Forum: X’D , T’Q and X’Q
8 comments
IC 7805
03/28/2016 10:15 AM
I wish to understand the complete working of IC 7805 with its internal circuit...i have tried google and also i did refer many of the books but still no info about its working...
Re: IC 7805
03/28/2016 10:52 AM
Try LM-7805 datasheet, Fairchild, and 78xx in wiki.
Did Indecent Exposure create the need for darkroom ?
United States - Member - New Member Hobbies - HAM Radio - AC9JZ extra
Re: IC 7805
03/28/2016 11:08 AM
There is so much data available about this IC, it may be possible miss it.
Try http://pdf.datasheetcatalog.com/datasheet2/9/0p4t1g1lw0spoo5ukh2s1uxchzky.pdf
and http://pdf.datasheetcatalog.com/datasheet/fairchild/LM7805.pdf
I hope that helps you.
The only dumb question is the one you didn't ask.
Re: IC 7805
03/28/2016 12:06 PM
Re: IC 7805
03/28/2016 12:43 PM
A linear voltage regulator consists of a voltage reference, a comparator, and an output circuit.
Here is a simple voltage regulator that shows the principle:
The zener voltage reference is D1. The comparator is Q1. When the output voltage drops, Q1 turns on Q2, letting more current through and raising the output voltage. If the output voltage is too high, Q1 turns off Q2, reducing current and lowering the output voltage.
The schematic for the 7805 is more complicated, but you should be able to spot the voltage reference diode (on the left), the comparator circuit (center) and the series pass output circuit (right side) between input and output.
Re: IC 7805
03/28/2016 12:54 PM
Re: IC 7805
03/28/2016 1:08 PM
http://www.righto.com/2014/09/reverse-engineering-counterfeit-7805.html
There are plenty of raw photos in there for you to literally see how the inside of this chip looks like !
Do understand that each chip maker have their own design, but concept and function of a 78xx remains the same eh!
Re: IC 7805
03/29/2016 11:40 AM
I find it hard to accept that you spent any appreciable time looking for the answers for yourself. Take this trivial search, for instance:
... which yielded about 16,000,000 results, or this rather more complex effort:
... with 430,000 results.
Good Answers: 73
Re: IC 7805
03/30/2016 12:27 PM
Did you get the answer you were looking for? If your DC voltage is a little too high, do you know what to do to drop it a little bit without wasting a lot of power in the form of heat?
Register to Reply 8 comments
JohnDG (1); Mike Proctor (1); NotUrOrdinaryJoe (1); Ramm (2); Rixter (1); SolarEagle (1); terrapin (1)
