Previous in Forum: Borrowing 1 Leg of a 240 Volt Feed   Next in Forum: Que On Overvoltage
Siemens LMV 51.1 Can Bus Actuator Position Fault
04/05/2016 2:58 PM
Dear all I am stuck with Siemens LMV 51.100C2 Can Bus Actuator Position Fault Error Code 15 Diagnostics 01. Kindly suggest me solution
Pathfinder Tags: BMS LMV 51.1
Re: Siemens LMV 51.1 Can Bus Actuator Position Fault
04/05/2016 3:56 PM
04/05/2016 5:45 PM
Turn the radio up and ignore it.
Or ask Siemens for help.
04/06/2016 7:01 AM
Please explain why the solution did not become apparent during the telephone call that took place to the equipment manufacturer.
04/07/2016 7:11 AM
You can go to Siemens' online support at (https://support.industry.siemens.com/tf/us/en/), and there you can pose as many questions as you like in terms of Siemens' equipment, and you'll definitely find someone out there answering your query,... Just have a try!!
I hope this helps!!
Just live and .. Learn!!
Register to Reply 4 comments
Ali18 (1); lyn (1); PWSlack (1); SolarEagle (1)
