Previous in Forum: Vortex Shedding Question   Next in Forum: Permissible Tubesheet Construction from Plate Material
11 comments
Estimating Torque?
04/06/2016 7:04 PM
I am trying to build something to push clay from a cylindrical container (cylinder 4"ID and approx 18" long) down teflon tubing to feed into a clay 3d printer. Currently I am using compressed air to move the plunger and the clay. I want to convert the set-up to use a geared motor and a threaded screw to push the plunger but I do not know how much torque I might need. I am currently pushing the clay at in a range of 45-100psi. The psi changes based on the stiffness of the clay that I load into the container. Is there any way to make an educated guess in a conversion? I just need an idea to help in my motor selection. (the clay stiffness ranges from hummus to soft cookie dough) thanks for any ideas/help!
Re: estimating torque?
04/06/2016 7:16 PM
Your area is A = π × 22
12.56 sq inch
1 pound per square inch = 1/225 * (39.4)2 = 6.9 N/m2.
= 690kPa
http://www.onlineconversion.com/
04/06/2016 7:21 PM
Wurst case of 100 pounds per square inch on a 4 inch cylinder. A 4 inch cylinder has about 13 square inches so you will need to exert about 1300 pounds on the piston driving the clay. The motor can be of any size you want (change gearing to get 1300 pounds of force). The question is how fast do you need to drive the clay (volume/min, sec, etc.), that will tell you the power you need.
Have you considered hydraulics?
Or linear electric actuators?
http://www.globalspec.com/search/all?query=linear+electric+actuator&newSearch=new
http://www.amazon.com/Heavy-Duty-Linear-Actuator-Stroke/dp/B012YAY9NM/ref=sr_1_2?ie=UTF8&qid=1459984623&sr=8-2&keywords=electric+actuator
04/06/2016 7:30 PM
Wurst case? Is this a sausage extruder?
04/06/2016 7:35 PM
I'm hungry. Time for dinner. I'd like some schnitzel and sour kraut too.
04/06/2016 8:25 PM
You forget that you are playing to a very tuff house.
And whatever happened to throwing clay? Squeezing it seems so, so gauche.
Good Answers: 141
04/06/2016 8:06 PM
Google
Conchita Wurst
Perhaps
Plenty of room here
04/06/2016 7:48 PM
Re: Estimating Torque?
04/07/2016 3:42 AM
It depends upon how fast the material is supposed to come out. There is nothing about this in the original post.
Hint: power is torque multiplied by angular velocity.
04/07/2016 4:03 PM
Radius = Diameter/2 = 2"
Area = Radius^2 x pi
Force = Pressure x Area
Motor Torque = (Thread Pitch x Force)/(Gear Ratio x 2 x pi)
Note: Friction is not accounted for.
04/07/2016 4:29 PM
Deleted
Good Answers: 52
04/07/2016 10:39 PM
This 3D clay printer is a wonderful opportunity to exploit the non-Newtonian behavior of some clay suspensions. There is plenty of existing clay research such as
http://iwtc.info/2005_pdf/09-3.pdf
describing the sensitivity of clay viscosity to shear stress and/or shear stress history.
Then take a look at this article
https://en.wikipedia.org/wiki/Non-Newtonian_fluid
Especially look at the 'Bingham Plastic' section, leading to the opportunity to extrude a clay suspension at low viscosity (hence needing less torque due to lower piston force). Such a 'Bingham Plastic' will revert to a stable solid after the extrusion process.
With the right clay suspension, you could gain easy 3D printing and a reliable unfired result.
Mark Bingham
Relativity PL
Register to Reply 11 comments
Anonymous Poster (1); Brave Sir Robin (2); dvmdsc (1); lyn (1); PWSlack (1); Relativity PL (1); Rixter (1); SolarEagle (2); Tornado (1)
