Previous in Forum: HELP! Intergraph Caesar II UG HDPE Pipe Stress Analysis   Next in Forum: Reducers in Centrifugal Pump Suction
19 comments
RTG Wheel Alignment Problem
04/14/2016 3:57 AM
we have alignment problem in our RTG wheel
any suggestion how to check wheel alignment and adjustment
Re: RTG
04/14/2016 4:03 AM
You might start better by explaining "RTG" and having a decent personal identity.
Re: RTG
04/14/2016 5:26 AM
Yeah even Mr Google doesn't know what RTG is.
I'm thinking Rotating Toast Grill?
Or Rough Terrain Gehicle?
Re: RTG
04/14/2016 6:39 AM
One does have to register an username to be able to post as an Anonymous Poster.
Re: RTG
04/20/2016 5:58 PM
Get specs for vehicle from an auto repair manual or web site. Use tape measure, string, level to check. Or feel the tires for wear pattern. -- JHF
Re: RTG Wheel Alignment problem
04/14/2016 6:38 AM
  • What is it that leads to the concept of an alignment problem with the RTG wheel?
  • Why is the RTG wheel's original equipment manufacturer's operation and maintenance manual not to hand?
  • Why is there no standard maintenance instruction available at the facility to enable a periodic check and adjustment to be made to the RTG wheel by in-house maintenance personnel?
  • What was the outcome of the telephone call to the RTG wheel manufacturer?
  • Etc.
04/14/2016 10:00 AM
thanks
these all Questions Are really sensible and appreciate able
-we have RTG jerking problem leading to Motor overheating
-Tire worn out problem
-Maintenance manuals not covering alignment
-periodic maintenance team just beating about the bush
04/14/2016 10:26 AM
Then:
  • Change the tyre.
  • Obtain advice from the manufacturer.
  • Re-train the maintenance team.
04/14/2016 10:38 AM
to take advice from the manufacturer
is wothfull
04/15/2016 3:40 AM
The word <...wothfull...> has no meaning in the English language.
04/15/2016 5:21 AM
"Wrothful" would be archaic, meaning full of rage; "worthwhile" is perhaps a better guess.
04/15/2016 5:56 AM
I'm going to be generous here and say that I think that's an attempt at the opposite of "worthless".
04/14/2016 9:48 AM
Read the manual!
Ask the manufacturer of your rubber tire gantry crane.
Have a clue!
04/14/2016 11:13 AM
Is this part of a Turbo Encabulator?
https://www.youtube.com/watch?v=rLDgQg6bq7o
04/14/2016 11:14 AM
Yes you should have an "as built" set of specs for this equipment somewhere, showing wearing parts maintenance and repair parts as well as source information...This will show tolerances and specs for all wheel parts....
Example...
Good Answers: 70
04/14/2016 12:51 PM
It's typical for companies that operate this type of equipment to toss out all pertinent operation and maintenance manuals right after the equipment is commissioned and operating. Then 2 years down the road, everyone is scratching their heads and asking, "where did we put the damn manuals"
Good Answers: 181
04/14/2016 2:05 PM
If RTG means what I think it means then laser alignment is the best option. For dual drive systems then speed control by infra-red paralleling is normal.
If the tires are worn then forget any of the above.
04/15/2016 3:40 AM
Still wonder how you established the alignment problem when you do not know how to check the wheel alignment....
Also still wonder what RTG refers to . . .
04/15/2016 3:41 AM
Quite
Re: RTG Wheel Alignment Problem
04/15/2016 6:09 AM
There is an <...alignment and adjustment...> problem to overcome in this thread, which has not been addressed yet.
http://www.acronymfinder.com/RTG.html
Eschew obfuscation.
<unsubscribes>
Reply to Forum Thread 19 comments
atiq6811 (2); Circuit Breaker (1); dj95401 (1); IdeaSmith (1); lyn (1); PWSlack (6); Randall (1); Rixter (1); SolarEagle (1); TonyS (1); Tornado (2); user-deleted-1105 (1)
