Previous in Forum: Rating of Induction Motor   Next in Forum: Motor Current Discrepancy
13 comments
Amount of Starting Current of a Rotary Compressor
04/21/2016 10:00 AM
I want to know what could be the value(amount in amperes)of starting current of rotary compressor of a 1.5 Ton air conditioner(carrier make) whose rated running current is 6.7 Amps. Also whether locked rotor current and starting current is same in such types of machines ?
Will anybody help please ?
Re: Amount of Starting Current of a Rotary Compressor
04/21/2016 10:04 AM
A1) Between 5 and 7 times the FLC.
A2) They are the same.
Good Answers: 804
04/21/2016 11:13 AM
The peak starting current is always the same (unless a reduced voltage starting method is used) per what PWSlack said. The only thing that changes with different loads is the acceleration time.
So was this just to satisfy curiosity, or do you have some sort of problem to solve related to that?
Good Answers: 42
04/21/2016 12:18 PM
First of all translate 1.5 ton A.C. in kW. Second, translate it in HP.
For instance see:
http://www.rapidtables.com/convert/power/ton-to-kw.htm
Now see also at the motor shield what locked rotor code letter is written.
Check in a book-NEC Table 430.7(B) Locked-Rotor Indicating Code Letters for instance
instance- what it does means k=kilovolt_amper/hp.
Multiply 1000 with HP and with this k and divide it by sqrt(3)-for three phases
and by voltage.
Let's say the code is J then k=7.99.
1.5 ton AC=5.27 kW [ 7 HP].Voltage 480 V.
Ilocked=1000*7*7.99/sqrt(3)/480=67.27 A.
Julius
Reply Score 2 for Off Topic
Good Answers: 42
04/27/2016 5:05 AM
Sorry, I forgot Thermodynamics and EER!
I read the shield plate of my air conditioner and I found 4 KW.
In Europe some time "kW" does not mean output power as usually in USA, but
the input power.
That means my air conditioner of 4 kW produces about 4.30*4=17.2 kW
or 58700 BTUH about 5 ton AC. Amazing!
Julius
04/21/2016 12:26 PM
I suspect the locked rotor would be around 55 amps, but it should say on the compressor.....A rotary compressor starting unloaded will have a starting spike, but I would be surprised if it was hitting LRA....and if it was, I'd be testing the start/run cap...
http://www.ebay.com/itm/Copeland-1-5-Ton-Scroll-HP-A-C-Condenser-Compressor-18-000-BTU-ZR18K5-PFV-800-/351144244298?hash=item51c1d3f44a:g:eO4AAOxytL9SIVCd
Good Answers: 42
04/21/2016 1:20 PM
It is better than all my calculation, indeed!
Julius
04/21/2016 3:21 PM
Well we don't know the voltage....but the question was whether a compressor should be drawing LRA on start-up....I've never seen a 3Ø compressor under 5 tons...So I'm assuming single phase 230v with start/run capacitor...therefore if you are hitting LRA on start-up, you have a problem....now you can short cycle a unit in any phase or voltage and cause the unit to draw LRA trying to start against pressure built up in the system, in which case the compressor should go off on overload within something like 5 seconds...but allowing the pressures to equalize and the compressor to cool down should remedy that situation....most systems have a time delay short cycling protection on them...
United States - Member - Old Member
04/22/2016 9:28 AM
Please call or go to your local refrigeration supply house, or, look up the information on the website for the manufacturer. They both have the exact info. you are looking for.
04/22/2016 12:49 PM
The're part sellers, not technicians...
04/22/2016 1:50 PM
I have worked at 2 parts houses between jobs. Don't sell them short, they have the information on hand. Some are better than others, just ask for the sharpest on the subject.
04/23/2016 12:40 AM
So why didn't you answer the question?
04/25/2016 9:42 AM
http://www.northamericahvac.com/carrier-bryant-payne-1-5-ton-scroll-condenser-compressor-p021-18211p-p021-18211/
I found this in about 2 minutes, more than enough info. for the info. needed. This is for R-22, if R-410 it's probably a Copeland.
Good Answers: 42
04/23/2016 12:49 AM
I am not specialist in refrigeration indeed. However, something does not fit here.
18000 Btu/h it is 5.27 kW but the rated current it is not for 1 phase of 230 V .
[In my opinion has to be 25-30 A or it has to be 3 phases.]
See -for instance:
http://www.ebay.com.au/itm/AIR-COMPRESSOR-MOTOR-ELECTRIC-INDUCTION-7-5HP-5-5KW-THREE-PHASE-2880RPM-/111575009990
Julius
7anoter4 (4); JRaef (1); PWSlack (1); Sasnak (3); SolarEagle (4)
