I'm hoping someone can explain to me exactly how an extrusion mold works, in simple terms. I'd also like to know what a USE Billet is and how the size of it relates to the die size.
The result of a mould is seen on the previous thread.
Imagine a piece of metal with a similar hole in it. The material Aluminium/PVC/plastic is molten and forced through the hole and allowed to cool and set.
A billet is a piece of material (aluminium) to be used for melting and extrusion,
The volume of the billet limits the length of a section(s).
Thanks for the reponses. Does anyone have a picture of an actual billet?
The kind of extrusion mold, I'm referring to is one for making stainless steel parts for furniture, but a picture of any kind would be greatly appreciated.
Hmmm....Not sure that stainless steel will be easy to extrude...Aluminium alloy is more usual, and there are some good stong attractive alluminium alloys.
An injection mould can be seen as a cavity formed by 2 or more moulds to the shape of the desired part. The molten material is then forced into the cavity and allowed to cool and set.
I am not familiar with the injection of St/St. The best known is casting aluminium-alloy in a sand filled mould and then machine the part to the desired tolerance.
The shrinkage of the cooling St/St must be provided for.
