Previous in Forum: High Voltage DC Capacitor   Next in Forum: Power Factor Correction Capacitor Efficiency
8 comments
Ceiling Fan Behavior
04/26/2016 10:55 PM
For couple of years my ceiling fan speed used to be slow when switched on but after some time it use to go up suddenly as if regulator switched to higher speed.
I do not understand this phenomenon. The capacitor is not bulged or burst.
Eventually for last two days it continues to run slowly only.
Re: ceiling fan behavior
04/26/2016 11:20 PM
Maybe its mechanically? Cant be seen from here.
Buy a new one that is speed regulated.
Have a fan and have fun!
04/27/2016 12:15 AM
Is it a Cavalier fan?
How many speeds?
Does it go both ways?
04/27/2016 12:42 AM
Sounds like a bad speed control or possibly a short in the motor winding's or bad capacitor or loose wiring connection....
04/28/2016 12:40 PM
Let's say the caps all busted given the wiring diagram that you have. This will left us at speed 1 right? Which means at low speed generally?
formerly Legolaz
Re: Ceiling Fan Behavior
04/27/2016 5:04 AM
You might want to look for burnt contacts inside the switch unit. If arcing is occurring, there is a possible fire danger.
04/27/2016 8:35 AM
I don't see a problem.time for replacement though and a supply voltage check
Good Answers: 27
04/27/2016 2:08 PM
The collected dust over time settled down in the motor and now coated the oil lubricant between the rotor shaft and the mounted bushing!
It is now time for the fan to be taken down for cleaning and new lubricant!
vsar
04/27/2016 5:23 PM
Test the capacitor. Don't just look at it.
Register to Reply 8 comments
Fredski (1); IdeaSmith (1); lyn (2); Peterpipper (1); SolarEagle (1); Tornado (1); vsar (1)
