Previous in Forum: Aliens Attack Maine   Next in Forum: Is The Shuttle Landing On Ocean Barges Like Space X??
10 comments
Steel Shims v Unshrinkable Resin Grout
05/17/2016 7:42 PM
Hi there.
looking for some advise or suggestions
Best method of packing gap between engineering block column and lintels. Block column to be built up to support the bearing load of the existing lintels . Best method to pack the underside of the lintels for strong support.Both lintel spans are 2100mm each.Much obligued for suggestions.Cheers
Warn Regards Jimmy 44
Re: Steel Shims v Unshrinkable Resin Grout
05/17/2016 8:08 PM
I would think the grout would be the best choice as steel tends to rust....
05/17/2016 9:43 PM
Just a reminder: No filler please
formerly Legolaz
05/17/2016 10:28 PM
You, and Jimmy 44, are a match made in Heaven.
05/18/2016 5:49 AM
I know that. Nice one Lyn.
Pretty sure it's my lucky number. I am #4
formerly Legolaz
05/18/2016 9:26 AM
"Who is #1?" - Patrick McGoohan in "The Prisoner".
05/18/2016 10:56 AM
I thought he was #6 way back then.
Seriously, I have had several revelations with #4. Back in college I stayed in a pad door #4 and graduated 04/04/04. Ideasmith pushed me "when I was a lego guy" to be number 42. Nope, I am number 4.
formerly Legolaz
Good Answers: 179
05/19/2016 7:55 AM
The tried and true method used here in the USA is to use opposing structural steel wedges (shims if you like) to force the lintel up as much as possible, followed by placement of a non-metallic/non-shrink grout injected under pressure.
Make sure that you pack the top of the CMU column voids with a quality building paper, tar paper or rosin paper, or else you'll be pumping grout all day long or until the cows come home.
05/19/2016 11:09 AM
"or else you'll be pumping grout all day long or until the cows come home."
Then it's no problem, you go take a nap while the cows run a shift pumping grout.
(That sounded wittier in my head, based off the old saying, "Party 'til the cows come home, then party with the cows.")
05/21/2016 10:54 AM
When I worked in the shipyard, we used a resin compound called "Chockfast" to level foundations for huge diesel engines and other massive items.
Mr.Ron from South Ms.
Good Answers: 179
05/21/2016 11:17 AM
Non-shrink non-metallic structural grouts should conform to ASTM C 1107.
Here's one of the industry leader's product:
http://www.euclidchemical.com/fileshare/ProductFiles/techdata/ns_grout.pdf
adreasler (1); CaptMoosie (2); lyn (1); Peterpipper (3); PWSlack (1); ronseto (1); SolarEagle (1)
